Turbo Boost Chip
Old Apr 6, 2004 | 08:02 AM
LuLuGoin2ADiesel's Avatar
LuLuGoin2ADiesel
When I looked at it originally he was asking $75 for it. That was a few weeks ago. So there must be some poor fellas that are picking them up. Thanks for the tip on the wastegate. Are there any harmful side effects from unplugging it? The chip made a tremendous difference. I reprogrammed it into the 60hp tow/haul safe mode until I can get my exhaust.
Cat -
Elverson, Morgantown, Chester Springs.... all such a beautiful area. I used to rip up and down on 401 on my street bike. I won't tell you what the weather is like here.... I want to stay on your good side.
Old Apr 6, 2004 | 08:08 AM
LuLuGoin2ADiesel
P.S.
I haven't gotten a chance to check the wastegate set up out yet. What did you guys use to plug the red line? Thanks!
Old Apr 6, 2004 | 09:46 AM
basstardo's Avatar
basstardo
I'd be glad you didn't purchase that one Lulu...that thing looks and sounds like a hunk of useless junk. Even from reading the How It Works section, I don't think this guy really even understands how the wastegate works with the turbo. It starts to crack open at 5psi and is usually all the way open at 8psi. Where he's getting the "when the waste-gate sees 16 pounds of boost it overcomes the spring pressure opening an exhaust dump releasing all extra boost into the exhaust stream" is beyond me.
Terry
Old Apr 6, 2004 | 07:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by LuLuGoin2ADiesel
P.S.
See the clamps holding the top intercooler tube connectors on? Just push the red line boot down on one of the clamp studs.
Old Apr 6, 2004 | 07:49 PM
LuLuGoin2ADiesel
Thank you much Cookie! So this just tricks the actuator giving you more boost without the wastegate dumping it off?
Old Apr 6, 2004 | 08:20 PM
CAT_man_963's Avatar
CAT_man_963
Yea basically - but I think if your boost goes way high it will still blow it open on it's own so that's why it's safe to do. I would imagagine gauges are a must to so this mod just to be safe. I'm waiting to do it until I get my Wicked Wheel in 'cause I already have stutter and I've read that this can make it little worse.
Old Apr 6, 2004 | 08:32 PM
LuLuGoin2ADiesel
Are you doing the WW yourself Cat? You should be very happy with it from what I've read. Once I get my gauges in I'll try the wastegate trick out. Thanks guys.
Splatts
Mar 31, 2012 07:13 PM
turbovet
Oct 21, 2008 09:55 PM
t.j.g.
Apr 26, 2005 04:14 PM
dogdude2003
Jan 22, 2005 05:46 PM
myst
Apr 13, 2002 12:13 PM
