Dragging front brake/ Star Adjuster?
Old Mar 9, 2004 | 07:05 PM
Tedster9's Avatar
Tedster9
I jacked up the front end on both wheels to lube the kingpin zircs, the drivers side wheel still spins free, pass. side wheel drags a tiny bit. No problem I thought, I'll adjust the star wheel off a bit. Doesn't seem to do much of anything, tried a BFH on the drum, is there something frozen or corroded? What's the best way to free that up?
Old Mar 9, 2004 | 09:03 PM
Jacks '66's Avatar
Jacks '66
if im not mistaken a drum brake should drag slightly when adjusted properly only a couple of rotations before stopping. maybe the problem is the other side?? just a thought...
Old Mar 9, 2004 | 09:17 PM
65f100xmas's Avatar
65f100xmas
the drums on my first 65 did that to used a lot of wd40 then used a torch to heat it up it worked but I would not use open flame around somthing covered with large amounts of flamble liquid but it was a pretty fire
fordno1
Jun 7, 2011 03:59 PM
mdula
May 4, 2011 02:48 PM
tomph
Jun 29, 2009 09:43 PM
Tedster9
Oct 10, 2002 11:31 PM
greghoffmann
Jun 8, 2001 07:40 PM
