302 engine flush?
Old Mar 9, 2004 | 05:51 PM
zackattack's Avatar
zackattack
302 engine flush?
I am a young one and don't know as much as i would like to so should i flush my '72 302 when i change the oil this time? it is in good running shape but has never been gone though, will this help or hurt? thanks
Old Mar 9, 2004 | 06:54 PM
averagef250's Avatar
averagef250
Are you talking about coolant flush or oil flush? Coolant flush is a good thing to do when radiator fluid starts looking cruddy or every year or 2. I only use crankcase flush products if I'm dealing with a very sludged up engine, after I fixed a bad head gasket or on a running core engine I plan on tearing apart and rebuilding before I take it out of the vehicle. I would worry about oil flush products destroying an older engine's valve seals and rear main seal. For older engines that have very bad looking oil and minor blowby I will run the engine very hard and change the oil immediately while still hot 3 times in a day or spread the changes over a couple of days. This has worked great for me several times and not worked only once.
Old Mar 9, 2004 | 06:57 PM
zackattack's Avatar
zackattack
i was thinking the same things about the seals, thanks!
Old Mar 10, 2004 | 10:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check out the information in the 302 engine forum also.
johnsjsj
Jun 20, 2012 09:16 PM
baseba8311
3.8 & 4.2L V6
Oct 26, 2006 10:07 AM
fordfinatic
May 14, 2006 10:21 PM
shawnf150
Feb 20, 2002 09:15 AM
