I'm replacing the mechanicl fuel pump on an OHC 4cyl.
there are 2 gaskets in the box and no instructions (even though the box says there are detailed instructions inside)
What's the deal with the 2 gaskets? are both supposed to be used? That's twice i've seen two fuel pump gaskets. they are identical.
I'm just hoping someone has run into this. the extra gasket would change the dimension the diaphram gets pushed wouldn't it?
