I have the same thing. I think that to be your problem. Either that or some wire came off like mine which I have to figure out. I'm sure you'll get some more specific answers.
yea my truck is the same way, what is a clockspring where is it too? never even heard of that can someone provide pictures or a how.... to cause being without my horn......is horrible!
What everyone's getting at is that this is going to be another big PITA. Basically on my truck I think the CS is OK, it's just that all the wires under the steering wheel column are not connected, someone messed with it that didn't have a clue what to do while trying to change the ignition, so I have to go through the whole thing wire by wire.
Do the airbag codes have to be cleared after changing the clockspring? I changed mine and I'm still getting a 51 code on the airbag light. If so, is the procedure to clear them accomplished by disconnecting the negative battery cable for 30+ minutes? Before I changed the clockspring I would get a 51 or 32 code.
A 32 code is a clockspring as when I replaced mine, it quit going off on the next start up and horn and cruise control worked again. I think you may have something else wrong.
The 5-1 code is..Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground .
It is located in the blue box up under the dash.
TNT...Interesting to know that the clockspring replacement did not solve that code. I realize that the short can be anywhere, but assumed that is was there.
I also have the 5-1 code and have never found the time to fix it. I suppose that a thorough investigation of all the wiring will be needed. I have the schematics for the system somewhere and will put my testers to it one day.
I would like to find someone who has solved their 5-1 code.
After you repaired 32, code 51 is pending meaning the internal fuse(32 blew fuse) in the air bag moniter is blown--must replace moniter(blue module)Later Ford trucks have a replacable fuse (10 amp) in eng. comp. fuse box. Flashing codes are by priority, fix 32 first and if another is more of a priority than 51 it would have flashed it. I always warned cust. of poss. 51 after repairs of lower flash codes.Early air bag systems were harder to price effectly because 1 in 5 would come up with 51 after repairing first flashed code----the one and only one the owner saw. LOL Blue
