master cylinder
Old Mar 7, 2004 | 07:53 PM
aaron o.'s Avatar
aaron o.
master cylinder
can a bad master cylinder cause a super hard pedal ?
Old Mar 7, 2004 | 08:26 PM
doccamel's Avatar
doccamel
More than Likley it's a bad power booster
Old Mar 7, 2004 | 08:37 PM
aaron o.'s Avatar
aaron o.
sorry, forgot to mention its a manual system
Old Mar 7, 2004 | 08:40 PM
doccamel's Avatar
doccamel
Manual? What is it on? any way... It could be a bad cyl. or a line problem. Of course manuals are not known for being very user freindly when it comes to force for stopping.
Old Mar 7, 2004 | 09:29 PM
JBIGTEX's Avatar
JBIGTEX
it could be your clutch or slave cylinder. i have a '95 f-150 and just had the clutch and slave cylinder replaced a week ago. as soon as i got it out of the shop the clutch was real soft and easy. so you may want to go a cottman transmission or ammco or something like that and they can do a transmission check usually check for free.
Old Mar 7, 2004 | 09:36 PM
aaron o.'s Avatar
aaron o.
its on a ranger, really no year, built from several vehicles for rock crawling. brakes and cab are ranger though. worked fine for longest time, now not.
Old Mar 7, 2004 | 09:42 PM
aaron o.'s Avatar
aaron o.
now that i think of it, a while back, a friend said a cyl from 70's f250 had bigger bore, hence move more fluid-etc. etc.. i installed one and didnt work like expected went back to ranger cyl, now feels like 250 cyl is still in it. i,m wondering if bigger cyl could have messed up proportioning valve.
Old Mar 8, 2004 | 10:28 AM
JBIGTEX's Avatar
JBIGTEX
yes it is possible. your valve could need to be replaced also. the 250 could have messed up the valve readings somehow. i would
Old Mar 13, 2004 | 01:49 AM
aaron o.'s Avatar
aaron o.
new master cylinder fixed it
Old Mar 13, 2004 | 01:51 AM
aaron o.'s Avatar
aaron o.
thanks for help
Old Mar 15, 2004 | 01:18 PM
JBIGTEX's Avatar
JBIGTEX
anytime
fatfenders
Sep 14, 2002 10:08 PM
scootin
1978 - 1996 Big Bronco
Mar 29, 2002 08:14 PM
Jul 14, 2001 06:50 PM
hanksmith
Jul 11, 2001 06:38 PM
ke6bnl
Mar 2, 2001 09:15 AM
