more 9 inch info?
Old Mar 5, 2004 | 11:21 PM
55forder's Avatar
55forder
more 9 inch info?
Hello guys,
I recently purchased a full size 1966 Ford car 9 inch rear end. I have been reading the 9" axle info, and am a little confused.
The 9 inch I bought measures 58" backing plate to backing plate. Will this fit into the rear of my truck?
I talked to a guy at bobsf100, and he says it will be ok (Im relocating the spring perches) But I figured a little feedback from you guys wouldnt hurt.
55forder
Old Mar 6, 2004 | 08:56 AM
mtflat's Avatar
mtflat
My guess is a qualified 'probably' but I'd do some measuring first.
Stock wheels will put your tires 1 5/8" closer to your box on each side. You'll have to check the clearance that you have now. The stock axle is 61 1/4" between backing plates.
If it looks to be too close you have the option of buying custom wheels with the needed backspacing.
Old Mar 7, 2004 | 09:04 PM
pcmenten's Avatar
pcmenten
Hi 55Forder.
If the axle came out of a Mustang, Cougar, or Ranchero then it will be short enough. The full size cars had a slightly wider axle.
What front-end do you have? We've been working on the documentation of a how-to for a Ford 9" with passenger car lug pattern. The basic plan is to use a F-100 9" and mid-70's intermediate driver side axle shaft for a drum brake setup.
I also have a disk-brake axle shaft from a big Lincoln that's the right length and the bearing retainer seems to bolt up to the F-100 axle just fine. I'll have to investigate bearing and collar fitment before the verdict is in on that lash-up.
Old Mar 7, 2004 | 10:41 PM
55forder's Avatar
55forder
I am running a Volare front end. My stock Dana44 measures 61" backing plate, to backing plate. My ford 9 (which is I believe out of a full size) measures 58". I plan on going with a little wider tire in back, with backspaced rims. I think I should be allright. The numbers do seem too perfect to be true.
I have the 5 on 4 1/2 bolt pattern all around now.
Hmm, we will see. Tomorrow I am working on motor mounts.
55forder
55forder
Sep 29, 2004 02:54 AM
55forder
Jun 2, 2004 03:19 PM
55forder
13
Feb 20, 2004 09:48 PM
55forder
Dec 9, 2002 07:10 AM
55forder
Electrical Systems/Wiring
Sep 9, 2001 11:12 PM
