Need Help! 4R55E/96 Explorer
ok alittle back story. this is a heavy duty rebuilt tranny that was done at 107k miles. it shifts great 1-2-3 no other issues. this all started after i was rearended and it shorted out some backuplights i had connected to the backup lights w/out a fuse(i know i know stupid) which blew the fuse for the backup lights which that fuse also controls the O/D. i will admit i had alittle higher amp fuse in there then i should..15 VS 10.
after blowing the fuse i lost o/d and everything else on that fuse. replaced it everything else came back but no O/D. so i had the solenoid replaced and it still did not fix the issue.
so i'm getting the code P0761 which is the overdrive shift solenoid. i had it changed by the same guy that rebuilt it at 126k miles that did not fix it so i just went and bought a new truck and only drove this one around town. now has 133k miles.
i know the P0761 is a pure electronic code, but i have no idea where to go from here. if i get some cash i'm going to being it into the tranny shop as it would be nice to have O/D back on the highway.
'96 4x4 4.0 OHV Explorer 133k miles. any help would be great!!!
I think that if it was me, I would disconnect the pcm and measure the OD shift solonoid resistance at the connector. You could also jump voltage to it and listen for the clicking sound. Possibly a bad connection somewhere. Did your tranny guy measure the old soloniod and compare to the new one? Do you still happen to have the old one?
Brian Mansour
15
08-16-2019 06:28 PM
jasvid
13
05-21-2012 05:00 AM
