460 timing
Old Mar 2, 2004 | 01:20 PM
460linc's Avatar
460linc
Question 460 timing
my dad and i are gonna replace the timing chain and gear our 460 soon. we found out that our 460 in our 76 lincoln was retarded 4 degrees so in order to liven it up again we were going to set the new one at zero. but i also heard that advancing it would improve the overall engive performance even more but my dad says we should leave it at zero and just see what its like. is there any disadvantage by advancing it instead, so that we dont have to spend all that time and energy getting back in there to advance it later on?
-chris
Old Mar 2, 2004 | 02:49 PM
Superdave's Avatar
Superdave
460linc
Do not set it advanced. Set it straight up at 0.
Then adjust your ignition timing to advance it. Start at about 10 -12 degrees BTDC.
Old Mar 2, 2004 | 11:00 PM
460linc's Avatar
460linc
superdave
o ok...thanks a lot for the advice man...i've been debating about that one for awhile...one more question: will there be a noticeable difference in low end power or will it just make the engine run more efficient?
Old Mar 3, 2004 | 01:27 AM
Superdave's Avatar
Superdave
460linc
You may notice some improvement.
This straight up timing issue moves the power band down to a lower, more usable rpm.
Old Mar 3, 2004 | 10:31 AM
460linc's Avatar
460linc
superdave
ok cool...thanx, ur help is much appreciated
TarHeelCars
Dec 15, 2015 08:46 PM
yappingboy
May 21, 2015 12:46 PM
Tyler S
Dec 26, 2014 01:20 PM
jason867
69
Sep 14, 2006 10:25 PM
Austin85
Dec 8, 2004 10:19 AM
