V10 malfuntion code
Old Mar 1, 2004 | 05:06 PM
dlwilemon's Avatar
dlwilemon
Question V10 malfuntion code
I have a 2000 x Ltd with V10. It has 40k miles on it and has always run like a dream until yesterday. I was sitting at the bank teller idling quiet as can be and then suddenly it sounded like I was in an appache helicopter. All the dash lights came on, the temp. guage went to red, the engine was bucking and missing and I barely had enough power to back into a parking spot. I turned the key off and let it sit for 5 min. and I started it back up and it ran like a dream for 2 miles and then the helicopter came back.
My error code is P1299 which is apparently some sort of cylinder overheated sensor malfuntion. Does this sound familiar to anyone? If so, were is this sensor on the motor? I would like to replace it myself if possible. Thanks for any help you can give...
Old Mar 2, 2004 | 09:12 AM
rlh68050's Avatar
rlh68050
P1299 is the dtc set when the CHT (cylinder head temp) sensor reaches a high value and the PCM puts the system into a protection mode. The misfiring you experianced was the PCM pulling power back by droping cylinders. There could be a real overheating issue here, or your sensor could be bad. But if this was the only DTC that was set, it was probably a true overheat condition. Check your coolant level.
Old Mar 8, 2007 | 06:16 PM
handyandy's Avatar
handyandy
I am curious to know how you found the code
I am experiencing an intermitent flashing dash light that seems to be a code
the no spark or flame indicator on my dash flashes once then 6 times do you know if this a code ?
Andy 2000 X XLT V10 Triton
Old Aug 16, 2007 | 08:26 AM
BTCRUZR's Avatar
BTCRUZR
rlh68050, what did you do to fix your problem? I have a similar problem with my 97 F150 4.6L, except my truck won't get into limp home mode, it just plain dies. P1299 comes up then. Did you just replace the sensor???
Old Aug 16, 2007 | 10:27 AM
emptyd's Avatar
emptyd
Any body know the trigger point for the PCM - that is at what head temp it transitions into protection mode and sets the code?
mendoAu
Apr 9, 2017 10:44 PM
devriesj39
Jun 26, 2016 12:35 PM
jwtaylor
Nov 15, 2003 08:55 AM
BigMattXXL
Modular V8 (4.6L, 5.4L)
Jan 24, 2003 02:40 AM
wafflerr
May 2, 2002 11:44 AM
