Bronco II Ford Bronco II
Missing and bogged down
Old Feb 25, 2004 | 01:57 AM
LeonR's Avatar
LeonR
Bronco II Losing power
HI just bought a 88 Bronco II It ran fine and the drove it the 10 miles home on the way had a stutter...
Now if I drive it slowly 35-45mph it seems ok but if you drive a little faster it will after a while (5-10min) lose power and not go above 40mph seems like it lacks fuel.
I found then that the fueltank is rusted though in some places.
My theory is that the rust got into the back fuel pump and is not supplying enough fuel to the motor.
Does that sound correct??
i am new to Bronco's so any help would be appretiated.
thanx
Old Feb 25, 2004 | 10:53 AM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I would test the fuel pressure when it loses power, it sounds like your on the right track but I'm think clogged fuel filter or the filter on the intank pump.
Old Feb 25, 2004 | 10:17 PM
LeonR's Avatar
LeonR
Thanx I have to replace the in tank pump any way as the tank is rusted and leaking. it is so badly rusted that you can not get the lid off to see. so i will let you know after this weekend when it will be done
Old Feb 29, 2004 | 07:05 AM
LeonR's Avatar
LeonR
I just replaced the fuel tank and pump as it was rusted, hoping it was the tank fuelpump that was causing the fuel starvation. Started it up yesterday and still the same problem.
Am going to buy a book today to see how to check the rest of the system .
Any help or advice will be appretiated.
When you look at the fuel reservour under the drivers side - whitch is return and supply?
Old Feb 29, 2004 | 01:11 PM
Ken00's Avatar
Ken00
Have you tested the fuel pressure, if its low the high pressure pump on the rail would be the cause on a two pump system.
Old Mar 16, 2004 | 05:04 AM
stupid red ranger's Avatar
stupid red ranger
Power loss may be due to clogged catalytic converter too. Just a thought.
Ron
jones91bronco
1978 - 1996 Big Bronco
Apr 26, 2014 01:10 PM
beno
Bronco II
Aug 13, 2003 07:24 AM
GeoTracker
Feb 27, 2003 04:11 PM
firestorm
Feb 13, 2002 07:56 AM
tomcrom
Jan 13, 2002 05:06 PM
