Coolant
Old Feb 29, 2004 | 03:28 AM
henryr5's Avatar
henryr5
Unhappy Coolant
I recintly replaced my lower radiator hose and thermostate and I am now losing coolant but I cant see where it is going there is no obvious leaks any ideas
Old Feb 29, 2004 | 05:56 AM
RTM's Avatar
RTM
A bad heater core or head gasket?
Old Feb 29, 2004 | 06:48 AM
henryr5's Avatar
henryr5
if it were the heather core wouldn't I have coolant in the cab or if the head gasket were blown wouldn't my oil be milky?
Old Feb 29, 2004 | 07:09 AM
RTM's Avatar
RTM
Yes and no. The heater core be leaking slowly but more times that not it will let you it's bad by the coolant getting all over the window if the heater is on. A bad head gasket doesn't mean your oil has to be milky. it could be burning the coolant in the cylinder but here again you may see white smake and have a good chace of over heating.
Does your over flow bottle hold coolant?
Old Feb 29, 2004 | 07:15 AM
henryr5's Avatar
henryr5
Yes my over flow bottle does hold coolant, but due to the lose of coolant in the system I put in about 1 leter of water coolant mix every week.
Old Feb 29, 2004 | 07:25 AM
RTM's Avatar
RTM
You could have the coolant check for exhaust gases. This will confirm if you have a good or bad head gastket.
I smell coolant burning when I get out of my truck but can't find any either. i di just replace the timing chain and i think I need to tighten up the bolts on the timing cover again. Like you I can not find a leak. I did just have a rad leak but I installed a new one.
Old Feb 29, 2004 | 07:30 AM
henryr5's Avatar
henryr5
Would I have to take the truck to a shop to have the coolant checked for exaust gases? or could I do it another way?
Old Feb 29, 2004 | 08:18 AM
RTM's Avatar
RTM
I think you can buy the tool to check it at the autoparts store? I have never done it myself.
Old Feb 29, 2004 | 09:02 AM
henryr5's Avatar
henryr5
Thanks
Old Feb 29, 2004 | 09:04 AM
whaynes's Avatar
whaynes
Coolant Loss
If the seals between the radiator and the reservoirs at its side are starting to go, you can lose coolant when the pressure builds while driving. You often won't have the obvious puddle. You can check for wetness and signs of coolant immediately below the raidiator or you can have a shop pressure test the radiator.
Old Mar 3, 2004 | 12:59 PM
tbaile16's Avatar
tbaile16
coolant loss
I have the same problem with my 95. No evidence of wettness or leakage. I smell coolant after driving but not if the truck is sitting cold. I have had a garage pressure test the radiator which checked ok. I also had the hoses replaced. My overflow tank seems leak free. No milky oil changes. I have been adding fluid to the overflow tank every now and then. I have thrown my hands up also.
Old Mar 3, 2004 | 02:40 PM
borin&strokin's Avatar
borin&strokin
Have you pressure checked, or just replaced the radiator cap. The seal can go bad, especially after being opened or messed with like you had to do when replacing the hoses/t-stat. Sounds like "leak tracer" and system pressure check time. Cheers.
Old Mar 3, 2004 | 02:45 PM
gypsyrose31299's Avatar
gypsyrose31299
Hmmm, been having the same probs too! Actually had this problem before and we're wondering if we're going to end up having to replace my radiator. We did put some of that Barrs (sp?) Stop Leak in and no problems until recently. Might just try that again.
barnhartred
Jan 17, 2014 01:41 PM
amd_038
Aug 20, 2011 08:03 PM
teppler
Jan 29, 2010 06:37 PM
hedhntr
Jun 10, 2006 09:53 PM
wresleu
Aerostar
Jan 23, 2006 12:52 AM
