For those of us who still have vac operated fuel pressure regulators, I was wondering if it was possible to relieve system pressure by applying vacuum to the FPR?
I was reading up on the FPR and if I'm understanding things correctly, the more manifold vacuum (higher RPM's) there is, the more the FPR lowers fuel pressure. If this is the case, could the fuel system pressure then be relieved by applying vacuum to the FPR with a hand pump?
Just curious. Looking for a way to make things a little easier in the future. IMO, it's easier to hook my vac pump to the FPR than it is to use my FP gauge on the shrader valve for relieving the pressure.
^^ ditto. Vacuum actually decreases as the throttle is opened, so the FPR "closes" and fuel pressure increases. At idle there is more vacuum, the FPR "opens" and allows more fuel to return to the tank. Hence why fuel pressure increases when the vacuum line is removed when the engine is running.
These are all great ideas. I have never really worried about relieving the fuel pressure, but then again I do end up smelling like gas. But When reading, my first thought was to depress the schrader valve on the injector rail, but that would still leave a lot of fuel in the lines.I was also thinking that vacuum is decreased upon acceleration.
