Relieving fuel pressure 86 f150 302 efi?
I'm getting ready to do a good bit of work on the top end of my 302 . I need to know how to relieve the fuel pressure . I can not find the inertia switch , i was under the impression it was near the steering column in the cab but its not there .
Can i pull the fuel pump relay and run the fuel out in a similar way to poping the inertia switch and running it out ?
Thank you , would have helped if i looked in the right place lol . There is a valve on the fuel rail that looks similar to a valve stem(pretty sure that's a schrader valve) . I'll look for the inertia switch in the right spot tomorrow .
The best way to do this, is pull the fuel pump relay. IIRC, it's the green one, right by the under hood power distribution box. I could have my year models mixed up....
Tripping the inertia switch can lead to it either not wanting to reset, or repeatedly tripping for no apparent reason.
Just take note that neither method will not fully relieve the pressure. The engine will shut off before the pressure drops to zero. It will generally leave 10-15 PSI in the rail, which is better than the ~40 PSI it would have normally.
Very little chance of having residual issues from unplugging the inertia switch, unless you broke the retaining clip(s) for the plug.
In fact, it actually gives you a chance to check for corrosion on the contacts of the switch and inside the plug.......
Quoted for truth.
Zach M.
03-05-2017 06:49 PM
fastbigblockford
10-20-2005 08:42 PM
RyanMiller
06-27-2005 11:03 AM
Farfaraway
09-30-2002 08:36 PM
