4.9L Performance throttle body spacer
Hey y'all, found this surfing the internet.
In all the "how to get more HP out of my 4.9" i always see exhaust and stuff , but never a throttle body spacer....
here ya go-
http://www.jcwhitney.com/webapp/wcs/...&storeId=10101
here ya go-
The intake system of any vehichle is a tuned instrument. The length, diameter and overall volume of the runners (individual tubes to each cylinder) are carefully matched with the plenum (common) volume, to create a specific power and torque curve.
Adding a spacer (throttle body or carb) increases the plenum volume and moves the tuning of the plenum higher in the rpm range. You might be thinking this is a good mod if you want to spin your engine faster, but no, even then, it is not a good idea, because the retuned plenum volume works against the runners.
On a fuel injected vehicle, the only way you'll see an increase in power would be a possible 5 or less horse gain on the top end, but this comes with a corresponding loss on the low end, so the net effect over the course of an acceleration run would be zero.
I know you're asking about EFI, but I see so many people putting spacers on carbed vehicles that it's even more important to say that the detriments to using a spacer with a carb are far more serious than EFI. With a carb, as plenum volume increases, the "signal" to the carb decreases, which means that a loss of low end driveability in direct proportion to the amount of plenum volume increase can be observed.
Carb spacers are only useful on racing engines, and even then it is hit-or-miss. Read any catalog of a reputable fuel system company (Barry Grant, for example) and it will say that the only way to determine if a spacer is appropriate is to make back-to-back runs (dragstrip or dyno) with and without. It is a murky science at best.
lanier1974
05-11-2018 01:23 PM
jmccracken1214
02-14-2017 08:46 PM
