Oxygen Sensor
Old Feb 27, 2004 | 02:05 AM
Caplax40's Avatar
Caplax40
Oxygen Sensor
Hey guys,
Found out I have a bad oxy sensor on my truck and am going to attempt to replace it tommorow. Where is it located on the truck and are they a pain to replace?
Old Feb 27, 2004 | 07:52 AM
Rockledge's Avatar
Rockledge
Cap,
Your truck has four (4) oxygen sensors...do you know which one is having the problem? Did you get a CEL or pull a trouble code? If so, the code number will tell you which sensor is having the problem. Also, keep in mind that an 02-related code doesn't necessarily mean that the sensor itself is bad, it could mean something else, such as a lean or rich condition.
Click Here For 02 Sensor Location Diagram
Old Feb 27, 2004 | 10:58 AM
Ken00's Avatar
Ken00
I think you would have three, one for each bank and then one after the Y pipe/cat.
Old Feb 27, 2004 | 11:08 AM
Caplax40's Avatar
Caplax40
Thanks for the reply's fellas. I don't know which one is causing the problem. When I went to Autozone the guy who read teh code more or less blocked my view and as soon as he said "looks like you got a bad oxygen sensor" immdeiately pulled the tester/reader and went inside, not giving me a look. Dunno what the deal was but he wasn't real forthcoming with info. I'm going to a different Autozone next time. Which brings me to my new problem. Coming home from class this morning the light clicked off and now doesn't appear. This means that the code can't be read now right?
Old Feb 27, 2004 | 12:15 PM
87 XLT's Avatar
87 XLT
The AZ guy probably cleared the codes, but since the CE light came on again there is a code stored in memory. Take it to the second AZ, have them pull the codes & write it/them down & post them here.
Old Feb 27, 2004 | 01:19 PM
Caplax40's Avatar
Caplax40
So you're thinking they're still stored in the memory then even though the light is off?
Old Feb 27, 2004 | 01:35 PM
87 XLT's Avatar
87 XLT
When the CE light comes on it means a trouble code has been stored & it will remain for approx 30 or 40 restarts. If the problem doesnt occur again in those 30 or 40 restarts the code will go away. Since the CE has turned off, you might get lucky & it wont come on again. If it was mine i'd get the codes pulled at the second AZ, maybe that guy will be more helpful & tell you the codes.
midsouth
Nov 5, 2012 08:23 AM
CarbonClear
Jun 9, 2011 11:33 AM
irishguyincc
19
Nov 12, 2005 08:56 AM
TommyH
Jul 31, 2004 09:58 AM
reberhardt
Dec 28, 2002 11:36 AM
