I took apart left side. I cleaned pads and rotor and relubed pins etc. ( these are new pins).
I took it out and it hooked right even harder. At 30 mph If I stood on the brakes it would lock up right front. I stomped on it a few more times and I felt the pressure drop a little bit ( like an ABS pulse.) Now it's ok? Stops nice and straight. I don't know if the ABS or the porportioning valve was hung up or a flap inside the brake hose?
