Front Brake pulls to one side
Old Feb 26, 2004 | 04:37 PM
paradiddle's Avatar
paradiddle
I get ( at slow speeds more noticeable) a pull to the right.
I replaced rotors, calipers, pads about 6 mos ago.
Neither side is hung up. When on the jack I can spin the wheels equally free and then brake.
There doesn't look like any contanimation, but I will clean pads and rotors as well as regrease sliders.
The only thing I can think of is a hose problem.
I'm leaving for Fla tommorrow pulling a trailer , 3000 mile round trip
Old Feb 26, 2004 | 04:39 PM
paradiddle's Avatar
paradiddle
I did check with my hand the heat on the splashguard near the rotor and the right hand is hotter than the left
Old Feb 26, 2004 | 06:25 PM
Fordcr's Avatar
Fordcr
I have same truck. put on rebuilt calipers and hoses, seemed to fix it. 92 E150 Chatau 5.8 E4OD with tow, 216000 miles
paradiddle's Avatar
paradiddle
I may be ok now....
I took apart left side. I cleaned pads and rotor and relubed pins etc. ( these are new pins).
I took it out and it hooked right even harder. At 30 mph If I stood on the brakes it would lock up right front. I stomped on it a few more times and I felt the pressure drop a little bit ( like an ABS pulse.) Now it's ok? Stops nice and straight. I don't know if the ABS or the porportioning valve was hung up or a flap inside the brake hose?
But it works fine now
Old Feb 26, 2004 | 06:29 PM
paradiddle's Avatar
paradiddle
Hey Ford Cr... Hows your transmisson?
I have had it checked at a shop and they said it was ok. It does shift kind of funny 2-3. I have a Banks Transcommand in it too.
Old Feb 27, 2004 | 05:21 AM
Fordcr's Avatar
Fordcr
at about 160k I serviced and added friction modifier. I have been good ever since. Did your back heat pipes fail yet?
Old Feb 27, 2004 | 06:12 AM
paradiddle's Avatar
paradiddle
What is a "friction modifier"?
Heat pipe oh yeah. I had a leak by the rear wheel 18 mos ago. I replaced most of it with 3/4 heater hose and 3/4 copper tube up to under the drivers door. It looks like I may have to replace that section next from under the door to the flex hoses.
Old Feb 27, 2004 | 06:27 AM
paradiddle's Avatar
paradiddle
A different lubricant? The shop that checked my tranny suggested I try synthetic oil?
Old Feb 27, 2004 | 04:39 PM
Fordcr's Avatar
Fordcr
LUBEGARD® ATF PROTECTANT:
at www.lubegard.com
Old Feb 27, 2004 | 04:40 PM
Fordcr's Avatar
Fordcr
check this post https://www.ford-trucks.com/forums/s...239#post710239
Old Mar 20, 2004 | 08:56 PM
Fordcr's Avatar
Fordcr
hey Paradiddle! how are the brakes doin?
Old Mar 21, 2004 | 08:44 AM
jpsartre12's Avatar
jpsartre12
I've got a 91 Club wagon w/ 302/ automatic and it shifts funny as well. It seems to downshift at odd times and upshift hard at low throttle and soft at harder throttle. I'm wondering if it's a vacuum modulator or vacuum line issue, but it's too darn cold to crawl under it now and look.
Old Mar 22, 2004 | 07:50 PM
paradiddle's Avatar
paradiddle
my brakes
my brakes worked fine. ran 3000+ miles to fla and back.
I am now in the market for a V-10 though. My truck just don't pull like I want it to. My typical day I'd run it at 70-72 mph with OD off (about 3000 rpm) while towing my trailer. My MPG at best was 8 mpg. 3.55 rear is not a good combo IMHO. I would get 3.73 or 4.10 to have a shot at running with OD on. It would help on hills with od off too.
That e350 v-10 I used last year has spoiled me. I could run that baby with OD on (same trailer) and go 75 +.
psdendurance
Aug 15, 2012 10:06 PM
kevin.ford-trucks
Apr 29, 2010 12:22 AM
Eastpark
1997 - 2003 F150
Jun 6, 2005 12:01 PM
paradiddle
Feb 26, 2004 07:34 PM
Joe Finn
1997 - 2003 F150
13
Feb 23, 2004 05:05 PM
