Older 302 swap HELP!@
Old Feb 26, 2004 | 12:45 PM
Fordfan4life's Avatar
Fordfan4life
Unhappy Older 302 swap HELP!@
I just replaced my 91 f250 302 with a lower end older 302
out of an older mustang 68? and I know it is a 302 and not a
289 cause thats what the guy told me. I have used both firing
orders 13726548 and 15426378 and have tried both of them 180
off and everything. It will crank over but will not start it has one
little very very little umph of a start and then goes back to
cranking. It is getting fuel cause I have pulled out a plug and their
wet and smell of gas. It definitely has spark cause when I pull off
the ignition coil wire you can hear it spark every so often.
Please help with any suggestions, thanks.
Old Feb 26, 2004 | 04:01 PM
Fordfan4life
Need advice badly need to get to work tomorrow!
Old Feb 27, 2004 | 06:46 AM
Maineiac's Avatar
Maineiac
Are you sure you are timing off of number one TDC? Check that number one is at tdc on the compression stroke and the make sure your rotor is pointing to number one that will give you a starting point.
Steve
Old Feb 27, 2004 | 01:21 PM
Fordfan4life
yep #1 TDC and rotor is on #1 What could cause it not to start with being timed.
Old Feb 27, 2004 | 01:31 PM
Maineiac's Avatar
Maineiac
Two things just poped into my head on this one you said you pull the coil wire and you hear it pop every so often? It should be a steady fire if it is working I would pull a plug wire and see if you have fire there as you said the plugs are wet and should not be verry wet if they are firing. In another post here someone metioned a ground from the manifold to the firewall as being very important for fire. I assume you are using the distributor from the 91 so as long as that was running you should be ok there but as with every thing else any of the parts in the ignition system could be bad. If all else fails see if you can pull codes and see what they say.
Steve
Old Feb 27, 2004 | 01:51 PM
Fordfan4life
I can't get any codes system ok 111 and the coil sparks constantly and the #1 plug sparks every so often but that would be correct cause it would spark every time the rotor came around. Doing good keep suggesting anything helps.
Old Feb 27, 2004 | 02:15 PM
88n94's Avatar
88n94
After you check the spark as Maineiac suggested, I have another suggestion. Remove the large hose on the intake that comes from the air filter housing and prop the butterfly there open a ways to let more air in. Use a large screwdriver or something big enough so it can't be sucked into the engine. You could also spray a small amount of starting fluid in there. I have done this a few times on fuel injected engines that just wouldn't start.
Old Feb 27, 2004 | 02:43 PM
Maineiac's Avatar
Maineiac
You said you used an older long block but what cam did you use? I believe the firing order is set by the cam and that should be your firing order. I know this may sound stupid but is your batery up? I have had computer systems not work correctly if the battery is low on amps the starter drags the battery down enough to make the computer fail I know this is off the wall but I have had it before.
Old Feb 27, 2004 | 05:25 PM
JohnnyRodney's Avatar
JohnnyRodney
What heads did you put on the lower end.Are the valves adjusted right, if not you might have a compression issue.
Old Feb 28, 2004 | 05:41 AM
RTM's Avatar
RTM
One thing comes to mind and that is did you change the distributor gear? The older motor (68) needs a cast gear and you newer motor (91) needs a steel gear. This could be a source of you troubles in that the distributor is no longer turning? I would suspect the steel gear would run for a while but it will wear out the cast flat tappet cam shaft causing timing issues if it doesn't break first.
Did you hear this motor run before? If not you may have a jumped timing chain.
What flywheel did you use? The 91 motor will take a different harmonic balancer and flywheel than the 68 motor because of the balancing differences, 91=50oz and 68=28oz. So unless you bought the specail dampner (balancer) for the front of the motor your pulleys would not line up and if you did install the dampner from the 91 to the 68 motor the timing marks are now way off! How are you timing the motor? If you do start it with the 91 dampner and flywheel if will shake like hell.
I would not use any starting fluid at this point until you know where you are at and you are sure everthing is correct. I have heard storys where to much starting fluid and an out of time motor don't mix very well, broken crank?
rahnpreston
31
Oct 14, 2013 01:04 PM
Brent Spoores
Feb 24, 2013 07:53 PM
littlebigfoot91
Jul 1, 2012 08:28 AM
axkiker
19
Sep 9, 2007 04:41 PM
raywa
Electrical Systems/Wiring
Mar 10, 2003 09:02 PM
