Sponsored by: Innova
SD CC back wall???
Old Feb 26, 2004 | 09:38 AM
V-104Me's Avatar
V-104Me
SD CC back wall???
Has anyone taken the back wall panel off there CC? If so, why does the panel have a raised area about half way down? I'm looking for a little more room for another sub.
Old Mar 3, 2004 | 09:36 AM
FYRDOC's Avatar
FYRDOC
The raised panel about half way down is where the cab vents are and yes removing that panel will gain you some room.....just don't recommend sealing up the vents.
Old Mar 3, 2004 | 02:49 PM
V-104Me's Avatar
V-104Me
Thanks FYRDOC! I want to cut a notch in the raised area to move the sub box against the wall. This will gain about an 1".
Old Mar 8, 2004 | 04:20 PM
jasontrucks76's Avatar
jasontrucks76
Hey my good buddy V-10 I found the solution to all our problems if you go back to the post I put out about 2002 cc subs help you will find a post from a fella instrument tech and he built a box for his 2003 and posted some pics. I built this box on sat. and installed 2 wO10 JL audios and maaaaaaan int frikin rocks I can easily say this out performs any setup Ive had in the extended cabs I did trim the molded plastic under the top ridge just below the back window 36" wide not so the box would fit but so I could add speaker grills and I am totally impressed If you want a good tite sound with great bass for all music this is the way to go!
Good luck man
Let me know what you do
Take care
Jasontrucks
ungerp
Jul 24, 2014 06:25 PM
Bruker
1983 - 2012 Ranger & B-Series
May 18, 2012 06:31 AM
Murph2006
Mar 7, 2008 09:48 PM
knucklehead11
Bronco II
Jul 13, 2003 10:37 PM
deckpros
Mar 9, 2003 05:46 PM
