super cab dent removal
Old Mar 2, 2008 | 09:43 PM
Murph2006's Avatar
Murph2006
i have a 79 supercab. On the driver side, a log skidder backed into it when the previous owner drove it to work. It dented pretty bad, the door and the area behind the door on the extended part. I havent got the panels out yet because they are brittle from old age. Does anyone know if i can get behind the plastic panel in the backseat and push the worst of it out or is it double walled? if it is double walled im not going to remove the panels because i know they will break. and also where can i buy aftermarked panels for the backseat? thanks
Old Mar 2, 2008 | 10:31 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
I actually think it is double walled. I have two supercabs in my driveway. 1 with and 1 w?o the inside plastic. The one without it is double walled so i would assume the other is too.
Old Mar 2, 2008 | 11:20 PM
OldMetal's Avatar
OldMetal
I know very little about body work but I do know the better you can straighten things out the better, how you do it is up to you but I know a ton of bondo doesn't last long.
Old Mar 3, 2008 | 11:35 PM
Murph2006's Avatar
Murph2006
i agree, i took autobody repair in highschool, and the instructor swore by bondo, but i always hated to put a whole lot in it, i would rather do the work straightening it out the best i can. I had a 63 f100 that i found enough bondo in to build the great pyramid lol. But i always used a stinger, it tacks a little stud like thing to the metal and you put a slide hammer on it and hammer away. I would like to have a stinger kit at home but i dont know where to buy one. I come from a small town, we dont have much of anything here lol.
Old Mar 4, 2008 | 02:31 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Murph, sounds like you had a pretty good high school. The high school here took out all the shops and converted the space to a baby sitting area for the childern of unwed mothers, so they could get there education. Thank your lucky stars you had what you had. It's a sad world.
Old Mar 4, 2008 | 07:38 PM
Murph2006's Avatar
Murph2006
well it wasnt actually the high school itself, the technological school here in the county worked with the highschool and allowed us to attend there classes for credits, but still we are lucky tohave it. the high school actually turned there shops into classrooms back in teh early 90s
Old Mar 5, 2008 | 09:40 AM
kyhiboy's Avatar
kyhiboy
Here is the one I bought. About $100.
http://www.harborfreight.com/cpi/cta...temnumber=3223
Old Mar 5, 2008 | 12:02 PM
Sgt Wonderful
you didn't tell up how good it works. Any Problems with it??
Old Mar 5, 2008 | 03:11 PM
kyhiboy's Avatar
kyhiboy
No, Simple machine not much to go wrong, just a switch and transformer.
Old Mar 6, 2008 | 11:49 PM
Murph2006's Avatar
Murph2006
hey thanks for showing me that tool and that site. I havent made the purchase yet, but i am sure it will be one well worth the money. I have looked almost everywhere i could drive around here, but never looked online, but then the only time i do anything online is usually on this site. But thanks!
Old Mar 7, 2008 | 09:50 AM
BigGrizz76's Avatar
BigGrizz76
be careful...if the dent is real bad it is highly likely that the sheet metal has been stretched so when you pull it out there will be too much material and it won't look right, you might want to look into getting some new skins and cut out the offending area and weld the new panels in...that dent puller is for smaller dents and if you use right you can actually shrink the metal...our sponsors should have the patch panels for the doors and you might have to fabricate something for the area behind the door.
Good Luck!
~Grizz
Old Mar 7, 2008 | 09:17 PM
Murph2006's Avatar
Murph2006
it seems possible to me, but do you guys think taking and old door and measuring the right size, cutting out, and placing in the area that needs repaired on the back part would work?
Old Mar 7, 2008 | 09:48 PM
OldMetal's Avatar
OldMetal
Anything is possible, the question is are you capable of doing it. I would suggest a visit to your local libary and check out some books on sheet metal repair and auto body repair. Before you do the work on your truck take an old door or something and practice on that, you can only learn so much from a book so some hands on work is needed before you start.
Body work is a skill that I wish I knew.
relli843
Jan 24, 2016 08:44 AM
DaricM
Jun 8, 2010 12:10 PM
tom41
20
May 16, 2008 05:10 PM
rebman
Jan 9, 2006 11:45 AM
phoneman71
Paint & Bodywork
Oct 8, 2005 07:06 PM
