Offroad & 4x4
Quick Question about a D44
Old Feb 23, 2004 | 03:06 PM
Idiomaticman's Avatar
Idiomaticman
i know this was posted a little while ago, but i just came across a HP D44 out of a 78 ford pick up. is that what i want if im going to do a solid axle conversion??? i need to know as soon as possible. also, it has drum brakes, will the discs off of my TTB bolt right onto it, or do i have to get a conversion kit
thanks,
Idiomaticman
Old Feb 23, 2004 | 03:16 PM
red_rocket's Avatar
red_rocket
78' axles never had drums..
Yes, a 78' HP 44 will work great for a SAS.
no your discs won't bolt on for a swap. the spindles are different.
Old Feb 23, 2004 | 03:19 PM
Idiomaticman
are you sure, because this one definatly has drums on it. the guy is near me and i found it off of ebay......so...what does it have if its not drum..??
Idiomaticman
Old Feb 23, 2004 | 03:36 PM
red_rocket's Avatar
red_rocket
judging by the tie rods, it looks like a EB 44.. but the width makes me think a early 70's 44. froma fullsize.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33728
Old Feb 23, 2004 | 03:39 PM
Idiomaticman
ya, thats it, you are sure about this? it is an EB, thanks
Idiomaticman
Old Feb 23, 2004 | 03:40 PM
Idiomaticman
ill ask him to measure it and then all post what the width is, can you tell me the width i should be looking for??
Idio
Old Feb 23, 2004 | 03:55 PM
Idiomaticman
"Well I took it out my self out of a 78 ford pickup not a bronco and ford never put high pinion in a bronco and measurements are 5 foot 8 inches from outside of drums it will fit perfectlyand because of high pinion you drive line angles would be awesome if lifted Thanks Kris "
there you go......is it for real??
Idiomaticman
Old Feb 23, 2004 | 04:07 PM
red_rocket's Avatar
red_rocket
well.. 68" WMS, it's from a old F-150. He may have pulled it from a 78' F-150, but someone else put it in there.
Old Feb 23, 2004 | 04:40 PM
Idiomaticman
red_rocket, what does that mean, so it is the correct length, but its from an older tham 78 F150, does that mean that it would work or not?
Idiomaticman
Old Feb 23, 2004 | 04:44 PM
85351ho's Avatar
85351ho
that front did nome come from the factory in a 77-79 f-150...sumone could have put it there but thres no tellin.
since it has drums its probably a pre 76...but im not too keen on f-150's
Old Feb 23, 2004 | 05:02 PM
Idiomaticman
so, you are saying it is out of a n F150, but is pre 76, so i shoudl just wait it out until i find one that is out of a 78-79?
Idiomaticman
Old Feb 23, 2004 | 05:21 PM
85351ho's Avatar
85351ho
yup..the only disadvantage of the 78-79 fronts is the c wedges cant be rotated or moved in, but you dont have to worry baout that since toyur just putting the in an f-150
Old Feb 23, 2004 | 05:49 PM
77'F-150Mudder's Avatar
77'F-150Mudder
I think it's interesting that this guy is claiming it's a HP D44 but there are no pics of the pinion side of the diff.
There's no way that's a HP if the drums are stock. I can't imagine why anyone would try to swap drums onto an axle that originally had discs.
I'd run away from that thing and never look back.
Just for kicks you should ask the guy for the BOM numbers off the long side tube.
Edit: I'm thinking about this and becoming more and more interested in the BOM numbers. I wonder if Ford did some of their usual weirdness and dropped a HP 44 in a late 76' or early 77' while they were still using drum brakes?
Old Feb 23, 2004 | 05:50 PM
tellico racing's Avatar
tellico racing
Idiomaticman
I would suspect that axle is not a high pinion....because of the drum brakes.
If he says they never used a high pinion in the 78-79 bronco...than he is misinformed.
It looks just like the front axle in my 69 f100 4x4
Old Feb 23, 2004 | 05:59 PM
Idiomaticman
i just asked for pics of the HP and the BOM numbers.
Can anyone inform me on what a BOM number is, and where i can reference this to find out what this axle really is?
Idio
