Hot Wire, power source, light wire ?
Old Feb 25, 2004 | 09:25 PM
bizkit64's Avatar
bizkit64
light Blue/red wire? (hey Million?)
The switches for my power windows needs a light source because they are illuminated from inside the switch. I was wondering if I need to find a wire that illuminates them only when I turn on my headlights or if I use a wire that will illuminate them whenever the car is on (like the lights in the stereo)? Is this possible? I have tested the blut/red wire and it is a switched hot wire---it is hot when the ignition is turned to accessory. I think that i will use this wire to illuminate my switches however I would prefer that the switches are only lit when I have my headlights on. Can someone help me with this?
Old Feb 26, 2004 | 01:04 AM
77redf250's Avatar
77redf250
the brown wire is used for the parklights it is either on or off. the cluster wire is connected to a resistor switch so it can dim the lights. you should be able to take your pick.
351Cleveland C4
Feb 19, 2013 08:44 AM
cdrmotorsports
Aug 23, 2010 08:14 AM
Calfdemon
Aug 5, 2010 09:03 AM
dbdbb
Electrical Systems/Wiring
Jun 4, 2010 08:57 AM
esco24
Oct 24, 2009 07:08 PM
