Hot Wire, power source, light wire ?
Old Feb 22, 2004 | 07:16 PM
bizkit64's Avatar
bizkit64
Question Hot Wire, power source, light wire ?
I am installing a spal aftermarked power window and power lock kit. The diagrams show that you hook the power sorce to the battery. I have installed numerous cd players in my time however I am wondering how I should hook these up correctly. I found a "hot" wire that is hot even when the truck is off. I am worried that if I use this wire the trucks battery will drain or I might burn up the motors. I am also unsure what the wire goes to so I am worried to tap into it. If I run my own wire directly off the battery will that work okay? Can somone please help me with this.
Old Feb 22, 2004 | 07:59 PM
acerockola77's Avatar
acerockola77
Welcome to FTE
It should just be fine running directly to the battery, you could probably run it off the ignition switch if you wanted.
Old Feb 22, 2004 | 09:40 PM
jbo2121's Avatar
jbo2121
you could run it to the constant 12 volt wire. that's how i wired my alarm and power locks, and i have had no problems so far.
Old Feb 22, 2004 | 09:49 PM
bizkit64's Avatar
bizkit64
Even If I have no idea what it is connected to. There are a couple wires that I have tested as hot when the car is off. Will it cause any problems to splice into them? For example say I splice into the ignition wire, is it going to draw power away from the ignition? Also, If I have illuminated switches that need a light wire what color is the FORD Light wire?
Old Feb 23, 2004 | 07:21 AM
65CJ5's Avatar
65CJ5
Andy, power windows use a motor so they'll draw some current. While you can tap into any constant-on 12V wire inside, you may draw too much current through that circuit and blow the fuse. Shouldn't hurt anything other than the fuse but it will get old real fast! That's probably why the mfg of your kit says to run it to the battery separately. That way you are not taxing an existing circuit.
I'm not sure what the color code on the gauge lighting wiring is but that's the circuit you want for the illumination part of it. It shouldn't hurt anything to tap into that circuit, the current draw is very low.
Stan
Old Feb 23, 2004 | 01:17 PM
bizkit64's Avatar
bizkit64
Question Ford Fuse Box
I have gotten some help on here about my power window and lock kit that I am installing however, I am still a little confused as to what I need to do. Right now I am looking for a picture of the fuse box or a diagram that tells me about it. People have told me that there is a 12v connection on the fuse box. Where is it?
Old Feb 23, 2004 | 02:17 PM
Franklin2's Avatar
Franklin2
I agree. Run off the battery to a add-on fuse(put the fuse near the battery). Then run the fused wire into the cab where you need it. If you run a 10 guage wire with a 30 amp fuse, you should have plenty of power to run both windows at the same time.
Old Feb 23, 2004 | 05:58 PM
shaggymane's Avatar
shaggymane
biz, try this.
https://www.ford-trucks.com/framered...3d800a9e58.jsp
Old Feb 23, 2004 | 06:23 PM
Mil1ion's Avatar
Mil1ion
Threads Merged
Please....... post all follow-up information to the original Thread.
Not doing so confuses the people who are trying to help you.
Why make THEM do all the work trying to track down other threads ?
Old Feb 23, 2004 | 06:46 PM
shaggymane's Avatar
shaggymane
Mil1ion,
I guess your talking to me. sorry. I'm real green about the manners around here.
somehow i thought the ford fuse box post hadnt' been replied to.
I have that link in my fav's and have used it to find a diagram of a fuse box when chiltons manual didnt' show one.
Old Feb 23, 2004 | 06:47 PM
Mil1ion's Avatar
Mil1ion
I was addressing Andy the original poster.
Old Feb 24, 2004 | 03:58 AM
77redf250's Avatar
77redf250
the wire for your lights is brown you can find it at the switch or drivers kick pannel
Old Feb 24, 2004 | 07:34 AM
bizkit64's Avatar
bizkit64
Thanks to all
I have successfully installed my lock kit. I chose to splice into the yellow constant wire on the ignition. My locks are working properly and I hope they stay that way.
My next project is to get the power windows installed and a security alarm system. I am planning on running one wire directly off the battery for these two components. Does any one think that it would be a bad idea to use one wire for these two devices or should I run two seperate wires?
Old Feb 24, 2004 | 07:51 AM
65CJ5's Avatar
65CJ5
Re: Thanks to all
Andy, you should be OK on the door locks. On the other items, if it were me I'd run seperate feeds as those are both important circuits. If either system blows its fuse the other system will still be up.
Stan
Old Feb 24, 2004 | 11:57 AM
Mil1ion's Avatar
Mil1ion
Instrument cluster lighting uses the Light Blue w/Red stripe wire.
