Wiring load question
I am installing a stereo that needs a 12V connection to an ignition hot, and then a 2nd 12V constant connection for the radio memory (clock, etc...). I figure that the 12V constant hot is easy enough as the memory wont be too much of a drain and I can splice that directly into the factory cigarette lighter which is always hot.
As for the 12V ignition hot, I want to plug it into the ignition accessory plug like the factory radio would go. But I am already using all 3 plugs and am not sure how much of a draw everything will be and if it will be too much. I am running my wipers off of 1 plug as it came from the factory. I am running a 2nd cigarette lighter (power outlet) which I do not want constant power to, and I am powering my tachometer with the 3rd plug.
I was thinking that the tach probably isnt too much of a draw and might be able to be spliced into the wiper motor wire as that is only used rarely (especially in So Cal). Then I could use the 3rd plug for the radio. I dont really want to run a new constant hot from the battery to power the radio as I would like the power to be off when the ignition is off. Do you guys think that these 4 items (tach, wipers, cigarette lighter, radio) are too much for the ignition power plug?
I really am curious as well due to me hooking up that 2nd power plug (cigarette lighter) as that will be used to power various items that might draw a bit, such as a GPS, or possible laptop converter, etc...
I could run a 2nd dedicated hot from the battery to that cigarette lighter, but I really wanted one that would power down when the ignition is off since the factory lighter is a contant hot.
Anyway, anyone out there with some good knowledge of the Bump's electrical system have some advice on which direction I should go?
Thanks in advance..
This is the "plug" that I am talking about and have filled. I currently have my wipers, an additional cigarettle lighter, and my tachometer plugged into it. I think what I am going to do for now is unplug the 2nd cigarette lighter and plug my stereo into it. I will figure out wiring for the second cigarette lighter later. I may end up picking up a second fuse box later as was suggested to me elsewhere and redoing the whole thing. But in the meantime, I want to get the radio installed and dont want to start blowing fuses or melting anything.
I am sure something like this in the future will solve any power needs I need:
Painless Wiring 70207 - Painless Performance Cirkit Boss Auxiliary Fuse Blocks - Overview - SummitRacing.com
But in the meantime, I am trying to hook this up using the existing wiring without creating any problems.. lol
I would wire in a relay, powered (with a fuse, of course) from the battery side of your starter solenoid. Then I would unplug your extra lighter, use that "outlet" the lighter was plugged out of to trigger/trip/turn on the relay and then get my power for the lighter and the radio from the relay. Autozone and NAPA both have a cool little blade style fuse block that has one power in and six fused outputs on blade style terminals in the +/- $10 range. If you use this and wire the input with heavy gauge wire, you could add extra relays/circuits as needed. 30 amp relays are cheap, $4-$6 and they really help take the load off of old, tired wiring and they are simple to install. Here is a dual relay setup from summit with the connector:
Vehicle Power Accessories 80238 - VPA SPDT Relays with Wiring Sockets - Overview - SummitRacing.com
HTH,
Gene
