H/X crossover installed!
Old Feb 22, 2004 | 08:32 PM
horsecop's Avatar
horsecop
Cookie, didn't we talk about this before? CeeJay just check the fittings when you do the fuel filter change. If you just installed it. I'd check it everyday for about two weeks. I did. That's just me. Glad of it too. Found the passenger side fitting weeping a bit. My fault. Not tight enough. Just tightened her down alittle more and it stopped. Simple solution to clean up the Valley in there. "Simple Green." Spray it down then use low water pressure to rinse it off. I did mine about three days ago and it's bone dry.
Note: Both Dale's and ITP's lines are fine, just your personal choice I reckon. Oh, Cookie I liked the coolant filter set up. If I get the wife a new truck I'll be a adding that!
Old Jul 25, 2004 | 01:07 PM
Hivolt's Avatar
Hivolt
What is the Max pressure that can be on this hose? Will a High pressure/High temp Hyd hose work in this application? I think the check often ideal is right on also!
Old Jul 25, 2004 | 04:16 PM
Quadzilla's Avatar
Quadzilla
I'm not sure of the exact pressure that the H/X hose needs to withstand, but it's way up there in psi. Something like 3500psi.
Earlier in the thread, someone asked what the H/X mod does. The high pressure oil rails run down each head of the engine, independent from one another, supplying the injectors with "hydraulic" pressure to fire. In the firing order, two adjacent cylinders must fire consecutively. Under certain circumstances, after the first injector as fired, the pressure hasn't built up in the rail to allow the second cylinder to receive full pressure. The H/X hose connects the two oil rails, allowing the pressure from one rail to help boost the pressure of the rail with the two cylinders firing consecutively. Hence, the second cylinder always gets full pressure. This mod often improves the idle quality, and overall smoothness of the engine. Some trucks benefit more than others.
Old Jul 25, 2004 | 04:47 PM
Hivolt's Avatar
Hivolt
Thanks for the reply, I'm looking @ buying/building on and needed to know a few specs on what to look for
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 21, 2019 01:40 PM
stevestroke01
Jan 5, 2015 07:15 AM
ttexastim
Nov 12, 2012 05:59 PM
Shake-N-Bake
46
Jan 9, 2011 10:51 AM
PowerstrokeJunkie
Jan 15, 2008 12:41 AM
