Help with powerstroke coolant conditioning
Old Feb 21, 2004 | 05:51 PM
pcerra's Avatar
pcerra
Reposting in this forum
Hello,
Can someone tell me how to service my 2001 F250's coolant conditioning. I bought the coolant additive and it says not to add it to the overflow tank. I am using the 3 in 1 test strips and as close as I can tell matching the colors the level is at 1.0. Where would I add the conditioner I don't see a cap on the radiator?
Also, where is the fuel filter located that should probably be changed. The truck has 37,000 Mi.
Thanks
Pat
Old Feb 21, 2004 | 06:42 PM
Calli's Avatar
Calli
Pat, It is OK to pour the conditioner into the plastic tank that you see. That is a pressure cap that you see on top and is part of the cooling system. It is not considered an overflow tank. On my '99 the fuel filter is located front and center on the top of engine. Under the plastic cover that removes with two nuts you will find the fuel filter.. Hope that helps, Carroll Allison
Old Feb 21, 2004 | 10:03 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The fuel filter is in the same place on every 7.3 PSD, right where calli said it is.
You have to add the SCA to the degas bottle, the radiator dosen't have a cap. Personally, I would add two bottles.
Old Feb 21, 2004 | 10:34 PM
bender97f250's Avatar
bender97f250
I agree with cookie, you should add two bottles.
Old Feb 22, 2004 | 07:38 AM
powerstroker250's Avatar
powerstroker250
If you are at 1.0 sca, 2 bottles will put you at 2.2 sca which is perfect.
Old Feb 22, 2004 | 08:32 AM
pcerra's Avatar
pcerra
Thanks folks!
I appreciate the help.
Old Feb 22, 2004 | 08:36 AM
HeatStroked's Avatar
HeatStroked
Or, do a good flush and put in the extended life "Gold" coolant.
Old Feb 22, 2004 | 10:05 AM
spitball's Avatar
spitball
Where do you get the extended life gold coolant, and how much does she run???
Old Feb 22, 2004 | 11:20 AM
HeatStroked
Zerex makes it and sells it through Pep Boys and Auto Zone.
Gold container GO-5.
I saw where Prestone just came out with it too.
Both meet the Ford specs. I think it's about $9.00 gallon.
Old Feb 22, 2004 | 04:49 PM
pcerra's Avatar
pcerra
Thanks
Any tips on how to flush? I would imagine starting with draining the radiator. Then run the garden hose in? What about the block.
By the way, the antifreeze is very toxic to dogs and cats. They love the way its tastes sweet. I raise labs so just thought I would throw this out for others following along this thread.
Thanks again for the advice.
Old Feb 22, 2004 | 04:52 PM
pcerra's Avatar
pcerra
By the way I added the 2 pints of the additive. I'm planning to check with the strips again soon.
What about these antifreeze filters that I see mentioned. Anyone have experience with these? Where are they installed?
Old Feb 22, 2004 | 06:15 PM
cookie88's Avatar
cookie88
FTE Emeritus
Look here.
Old Feb 22, 2004 | 07:44 PM
HeatStroked
Or here;
http://community.webshots.com/photo/...15594854KegNkJ
(4 pix, use cursor)
p_arbor
Jan 14, 2014 10:56 AM
bigkountry926
Jun 14, 2011 06:32 AM
mjtpolice76
69
Jan 15, 2006 01:43 AM
1explorer
Jan 27, 2003 04:54 PM
joeyd
1997 - 2003 F150
Oct 25, 2002 07:16 PM
