pitman seal
Old Feb 20, 2004 | 10:52 AM
bob arrington's Avatar
bob arrington
pitman seal
ive got a pitman seal that froze up from sitting all winter, can that be dug out from the bottom ? thanks , bob
Old Feb 20, 2004 | 11:23 AM
chaspsmith's Avatar
chaspsmith
What is a pitman seal?
Old Feb 20, 2004 | 12:55 PM
deermit's Avatar
deermit
Hi Bob, Napa sells a kit to replace the seal and it can be done on the truck.
Old Feb 21, 2004 | 09:32 PM
bob arrington
excellent , many thanks , respectfully ,bob. btw ,chaspsmith,a pitman seal is on the bottom of the steering box that goes on the shaft before the pitman arm does , which is what steers your truck, along with several other parts ,i learn some thing every time i log on to this site,good luck, bob
Old Feb 21, 2004 | 10:19 PM
GLR's Avatar
GLR
You have to pull the pitman arm, sometimes you can get the seals (there are two) out by starting the engine and turning the wheel against the stop, they might pop out... I've had better luck with a sheet rock screw and vise grips. Also believe there is a snap ring involved, as well as cleaning the rusty surface.
Old Feb 28, 2004 | 08:55 PM
bob arrington
excellent , respectfully , bob
Old Feb 28, 2004 | 09:23 PM
Torque1st's Avatar
Torque1st
Posting Legend
-And don't forget the filter...
Old Feb 29, 2004 | 03:09 PM
bob arrington
filter?
Old Mar 5, 2004 | 09:06 AM
bob arrington
the vice grips and screw worked great , many thanks,respectfully,bob
Old Mar 5, 2004 | 06:09 PM
Torque1st's Avatar
Torque1st
Posting Legend
Always install a filter on the return line if you do ANY work on the PS system.
Wix transmission/PS filter #58964
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Ford equivalent filter kit #XC3Z-7B155-AA
filter alone #XC3P-7B155-BA
Old Mar 5, 2004 | 11:20 PM
bob arrington
i never new that , respectfully, bob
Old Nov 29, 2008 | 03:57 PM
chaspsmith's Avatar
chaspsmith
I can't remember how to post stuff at this web site. Where do I go for help?
nissen4
Jan 18, 2017 04:33 PM
Pepinbilt
Aug 7, 2015 05:50 PM
Zazoos
Jul 21, 2015 03:06 PM
mauicruza
1966 - 1977 Early Broncos
Feb 27, 2015 04:51 PM
Corkwheats
Feb 12, 2015 06:01 AM
