1978 - 1996 Big Bronco
performance cam
Old Feb 19, 2004 | 02:26 AM
fordman_in_nv's Avatar
fordman_in_nv
performance cam
I recently bought a 95 parts truck it has a roller cam 351, with mass air. I'm going to be swaping the motor and trans into my 88. I'm also doing some upgrades while I'm at it and, I dont know if I'm stupid or just not trying hard enough but none of the web sites I've looked at list a good truck cam for the roller 351. I'm pretty sure a roller cam 5.0 has the same firing order but I dont want a high end racing bronco. So long story short, does any one know where I can get a good low end 4x4 cam for a roller 351?
Sorry about the length and thanks in advance.
Old Feb 19, 2004 | 12:47 PM
Kemicalburns's Avatar
Kemicalburns
i put the same motor into my 88 bronco to. the dizzy on the 95 is different then what you will need to run in your 88 . find a dizzy from a 93 351 and have the dizzy gear swapped for the one on the 95. otherwise it will get eaten up . just an fyi. i would call compcam, lunati, cranecam. there tech support is pretty good and should get you the right setup. what motor/tranny is in the 88 now?
BlackGold1955F100
Mar 18, 2013 08:27 PM
LindenBruce
Mar 10, 2010 08:57 AM
Show-N-Go LX
32
Nov 29, 2005 10:59 AM
termyt00
15
Jun 20, 2005 07:02 AM
dbc
May 4, 2003 10:53 PM
