Texas Chapter Join Chapter, Leader: LibTimothy
D60 front?
Old Feb 18, 2004 | 06:33 PM
izzybird's Avatar
izzybird
D60 front?
Is this a D60 front axle?
78 F250
vin X26SKBC0607
axle code: B4J
axle tubes measure 3.25" diameter
hubs 3.5" diameter
axle tag long gone, found some numbers on housing,pretty damaged(diff cover side) lower left housing tab:44-9F. lower right housing tab:C38 or 038
it is high pinion
don't know anything about D44's nor have one to compare. I know it's one or the other obviously. is this enough info? any help appreciated. I've tried searching forums, but I have prehistoric dial up. Needless to say I've spent hours, and barely got anywhere.
Old Feb 19, 2004 | 01:53 PM
Txquadhunter24's Avatar
Txquadhunter24
sounds like a D44 HD.
Old Feb 19, 2004 | 07:31 PM
izzybird's Avatar
izzybird
finally cleaned her up enough to make out some numbers on the long axle tube. from left to right it appears a this:
10 25 7 05 610040 4
4 Wheel Parts Wholesalers in Austin TX ran the numbers and claimed it is a D60.
Ford house was clueless
Whatta ya think?
Old Feb 19, 2004 | 08:14 PM
jesse460's Avatar
jesse460
if it has 44 cast into the web it is a 44
Blackfoot Big Block
Dec 28, 2009 09:25 AM
Thomasm67
20
Jan 23, 2005 01:44 PM
izzybird
Jul 9, 2004 02:01 AM
75FordF-250
Texas Chapter
Apr 25, 2004 09:40 PM
