D60?
Old Feb 18, 2004 | 06:47 PM
izzybird's Avatar
izzybird
D60?
Is this a D60 front axle?
78 F250
vin X26SKBC0607
axle code: B4J
axle tubes measure 3.25" diameter
hubs 3.5" diameter
axle tag long gone, found some numbers on housing,pretty damaged(diff cover side) lower left housing tab:44-9F. lower right housing tab:C38 or 038
it is high pinion
don't know anything about D44's nor have one to compare. I know it's one or the other obviously. is this enough info? any help appreciated. I've tried searching forums, but I have prehistoric dial up. Needless to say I've spent hours, and barely got anywhere.
Old Feb 18, 2004 | 08:56 PM
wick246's Avatar
wick246
The 44-9F says its a Dana 44.
Old Feb 19, 2004 | 07:38 PM
izzybird's Avatar
izzybird
finally cleaned her up enough to make out some numbers on the long axle tube. from left to right it appears a this:
10 25 7 05 610040 4
4 Wheel Parts Wholesalers in Austin TX ran the numbers and claimed it is a D60.
Ford house was clueless
Whatta ya think?
Old Feb 20, 2004 | 03:46 AM
85351ho's Avatar
85351ho
thats your problem there...lol
heres the easiet way to tell, look at the steering arm....3 bolt pattern=dana 44
4 bolt square pattern=dana 60
Old Feb 21, 2004 | 12:07 AM
SoCalDesertRider's Avatar
SoCalDesertRider
I agree with Wick246, "44-9F" tells you it's a 44. If it has ball joints, it's a 44, if kingpins, it's a 60.
Old Feb 21, 2004 | 08:30 AM
izzybird's Avatar
izzybird
couldn't find any bill of material numbers for D44 in '78, but did find them for D60. didn't match any of the D60 numbers for that year. Three bolts in a row on the steering arm. think you guys hit it on the head, must be a 44. since the tubes and hub are so big, you think it's an HD? thanks for your help, love this site! Now I'm gonna search these forums trying to figure out why my 2000 powerstroke's frontend sounds like a rattle can. looks like I'm replacing the frnt left hub assembly AGAIN! stupid sealed bearings .
Old Feb 21, 2004 | 03:39 PM
67-72williso's Avatar
67-72williso
Talking
It`s a 1978 dana 60 front with 4.09, open carrier, per Dana.
Old Jul 5, 2004 | 12:48 AM
muscletruck7379's Avatar
muscletruck7379
what(where) do you mean w/ the 3 bolt and 4 bolt?
Old Jul 7, 2004 | 09:50 PM
SoCalDesertRider
Muscletruck, HO is talking about the kingpin caps on top of the steering knuckles. Most Dana 44's I have seen have balljoints. Dana 30's have 3-bolt kingpin caps. Dana 60's can have balljoints or kingpins, depending on year ('91-down are kingpin, '92-up are balljoint, on F350's).
Old Jul 8, 2004 | 05:37 PM
muscletruck7379
ok, just kinda confused me cause my 44 has 4 bolts on top of the kingpin caps
Old Jul 9, 2004 | 02:01 AM
Hardcore4x4er's Avatar
Hardcore4x4er
get a 1/2 inch wrench and a 9/16 inch wrench, which one fits the cover bolts? if the 1/2 incher fits its a 44. 9/16 incher its a 60. I got the same axle the 44-9f its a d44
Blackfoot Big Block
Dec 28, 2009 09:25 AM
STGFordCrazy04
Jul 26, 2006 05:06 PM
75FordF-250
Texas Chapter
Apr 25, 2004 09:40 PM
izzybird
Texas Chapter
Feb 19, 2004 08:14 PM
