Front Dana
Old Dec 21, 2004 | 12:45 AM
Thomasm67's Avatar
Thomasm67
Front Dana
Okay i have a 76 F-250 hiboy after looking thru a couple of books it seems that i have a D44HD but upon actually looking at the front axle it is stamped 44 but also it is stamped 60f also a site said that a D60 would have 4" diameter hubs which i do maybe 5".But the Books say D60's weren't used as front ends til 78 so is very confused on what is actually the right axle in my truck and help will welcome.
Old Dec 21, 2004 | 12:58 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Dec 21, 2004 | 01:22 AM
ivanribic's Avatar
ivanribic
You shouldn't have a D60 unless someone swapped it in there. Is the 60f in the webbing of the pumpkin or on the axle tube?
Old Dec 21, 2004 | 01:29 AM
Thomasm67's Avatar
Thomasm67
It's in the webbing
Old Dec 21, 2004 | 09:19 AM
mark a.'s Avatar
mark a.
Sounds like a stock 44 h.d.
Old Dec 21, 2004 | 10:04 AM
Thomasm67's Avatar
Thomasm67
Probly but if it is the original owner must have ordered hubs you would find on D60 cause they are huge my uncle has a 74 250 hiboy and his hubs are small compared to mine.
Old Dec 21, 2004 | 11:09 AM
mark a.'s Avatar
mark a.
The h.d. has the big hubs. l. d. used the 1/2 ton style hubs. Thats the only difference I know of.
Old Dec 22, 2004 | 12:46 AM
fordfury469's Avatar
fordfury469
thats not really true i know of two 75 or 76 3/4 ton pickups here with dana 60s in the front of them and have never been swapped out.
Old Dec 23, 2004 | 08:33 PM
Father Ford's Avatar
Father Ford
Dana 60 was not used in front until 78.
Old Dec 23, 2004 | 08:35 PM
fordfury469
ok was a dana 70 used in a 3/4 ton in 75
Old Dec 23, 2004 | 08:37 PM
fordfury469
this 75 or 74 im not sure what year but i know it was a 78 or 79, 3/4 ton pick up had a dana 60 in the front and a 70 in the rear, the guy bought it new in the 70s.
Old Dec 23, 2004 | 08:47 PM
Father Ford
Dana 70 was not used in f250s only f350s. 74-75 f250s used the dana 44 Ld or Hd front and dana 60 rear.
Old Dec 23, 2004 | 08:52 PM
fordfury469
yeah this pickup had a 70 rear and 60 front, when we blew the rear end up yeah some how you can do that, we thought it wasa 60 so we ordered parts for it and they were wrong, then we checked the tags and it was a 70 rear, then we blew the front up, and it was a 60, i dont know if you could of ordered it with a 70 and a 60.
Old Dec 24, 2004 | 12:11 AM
theguy_88's Avatar
theguy_88
a 3/4 ton with a dana 60 front and dana 70 rear is what ford called a camper specal. the camper specal is like a 3/4 ton heavy duty
Old Dec 24, 2004 | 12:16 AM
theguy_88's Avatar
theguy_88
and they also had f-250 dana 60 front and dana 60 rear witch was a option for a snow plow application.
