transmission conversion help!!
Old Feb 18, 2004 | 04:34 PM
83shotbed4x4's Avatar
83shotbed4x4
i have an 83 f1504x4 300ci with 4 speed manual. i have a 351w and an aoutomatic tranny i am putting in. what do i need to do to install my transfer case on the automatic tranny? will the input shaft on the 4-speed work?
Old Feb 18, 2004 | 05:06 PM
wick246's Avatar
wick246
Is it a C6 transmission? You will need a C6 with the 4wd output housing and shaft for a bolt up installation. There is another thread somewhere about converting 2wd C6's to 4wd output.
The manual shaft will do nothing for your new transmission except act as a crowbar to help line up the bolt holes.
Old Feb 18, 2004 | 06:10 PM
red_rocket's Avatar
red_rocket
it would be alot easier and better to just leave the 4 speed in it.
But, if you really want the C-6, you just have to change the C-6 to a 4wd tailhousing.
Old Feb 18, 2004 | 06:12 PM
steell's Avatar
steell
I think all you would need is a flywheel for the 351. The bellhousing will bolt up.
Old Feb 20, 2004 | 12:35 PM
83shotbed4x4
i have a replaced hip and the 4-speed is not the easiest to push!! i will find out what the tranny is, i do know that the 351w is fuel injected maybe that wil help. but i'll give yall the id asap. do i need to find a tailshaft then, that is 4 wheel drive?
Old Feb 21, 2004 | 03:21 PM
83shotbed4x4
it is a c6. i just don't want to have to search all oaround to find a 4-wheel drivve c-6. figured i could use the automatic i have.
Holo
Apr 4, 2016 08:05 PM
Mike Barry
1978 - 1996 Big Bronco
Feb 20, 2011 06:14 PM
1983FORD
Feb 27, 2008 10:04 PM
Ford_By_Four
Engine Swaps
Dec 16, 2004 07:38 PM
tmnelson
Jul 30, 2002 08:34 AM
