crooked wheel?
Old Apr 4, 2016 | 10:47 AM
Holo's Avatar
Holo
crooked wheel?
ok so i have an 83 that will track strait down the road but my steering wheel is clocked to the 1:30 position while i'm going strait.
can anyone help me fix this?
83 f150 4x4 302 4 speed
thanks in advance
Old Apr 4, 2016 | 11:19 AM
bcamill's Avatar
bcamill
You have two choices that I know of and you will not want to do either until needed. First, Take the steering wheel off with the wheels straight and reinstall in correct position. Not an easy task. When it comes time for an alignment, the shop will correct it when the are working on the front end and tie rod ends.
Old Apr 4, 2016 | 02:02 PM
Franklin2's Avatar
Franklin2
You want to make sure the steering box is centered or it will have a lot of play in the steering when you are driving straight.
Old Apr 4, 2016 | 08:05 PM
ctubutis's Avatar
ctubutis
My steering wheel is indexed and can be correctly installed in only one orientation.
Re-orienting the wheel will mess with the turn signal switch canceling mechanism.
dr_rock
Oct 25, 2018 04:18 PM
jonrjen
6.7L Power Stroke Diesel
Feb 20, 2015 07:26 PM
duggyb
13
Dec 23, 2013 06:10 PM
dog150
Dec 14, 2007 04:15 PM
seumas
Sep 25, 2004 08:38 PM
