offenhauser sucks!!!!!
Old Feb 17, 2004 | 08:14 PM
bigblocksix's Avatar
bigblocksix
well heres the story, my buddies buildin up a 300 6, prety nice motor, we ordered an offenhauser dual port intake for it, when we got it i knoticed some horrible amounts of casting flash arround the ports, we ground most of it off but that was some prety crappy attention to detal. when we put the intake on all of the bottom bolts had to be modified to clear the runners, thats just crap. after we got all that straightend out we got the carb offenhauser recomended, a holley 390 and went to put it on. we attempted to put the carb on but the throttle linkage was hittin the manifold. we figured ok we'll get a 1 inch carb spacer and try again. we got the spacer, put the studs in the intake and went to drop the spacer on, no go. offenhauser drilled the holes in the intake crooked, the studs threaded in but pointed off on different angles. the holes for the carb studs look like they were drilled by hand and tapped by someone that was somewhat drunk. save youself the headache and stay away from offy!
Old Feb 18, 2004 | 03:56 AM
Ford_Six's Avatar
Ford_Six
I have had no problems with mine- have you contacted them, and asked for a replacement?
The linkage hitting is a known issue with these intakes- most people put the carb on backwards to solve it.
Old Feb 18, 2004 | 04:50 AM
scsmitty78's Avatar
scsmitty78
No problems here. Mine worked just fine.
Old Feb 19, 2004 | 06:04 PM
5_labsownus's Avatar
5_labsownus
Mine "C" fit great, no reworking and a holley 108-18 spacer is 5/16 inch and that fixed the linkage problem!
Old Feb 19, 2004 | 06:35 PM
80broncoman's Avatar
80broncoman
Anybody have a 4bbl intake for sale? I am in need of one.
Jim
Old Feb 22, 2004 | 08:18 AM
bob arrington's Avatar
bob arrington
big blocksix may know of one ,bob
Old Mar 18, 2004 | 02:01 PM
Mky67156's Avatar
Mky67156
I did the 390cfm setup on my offy intake. what did you use for your throttle bracket?
Old Mar 18, 2004 | 11:46 PM
my79f's Avatar
my79f
just wondering are there any other places besides jegs to order an offy intake. the are on backorder till mid april.
Old Mar 19, 2004 | 04:52 AM
Ford_Six's Avatar
Ford_Six
JCWhitney has the Cseries only. That's the single plane one.
Old Mar 19, 2004 | 08:10 AM
Mky67156's Avatar
Mky67156
If you use the last four digits of the jegs part number on the summitt racing manufactures listing under offy it will come up. It's also cheaper. Put 6019-DP in the block.
Hope this helps.
Old Mar 19, 2004 | 08:11 AM
Mky67156's Avatar
Mky67156
Heres the link
http://store.summitracing.com/defaul...earchtype=both
MattEich
13
Nov 3, 2015 11:09 AM
mycods
Apr 27, 2015 06:52 AM
Biblethumpncop
22
Jan 13, 2015 10:27 PM
Johnsbelljr
63
Jun 24, 2014 08:42 PM
last dollar
Oct 6, 2011 08:24 PM
