hi i was wondering if any one has any suggestions for an automatic 93 ford ranger that will stall when accellerating from a stop or slowing down to turn. it seems to do it more often when its raining or cold out.
i have taken it in numerous times and have changed the alternator, fuel filter, cleaned the throttle box, flushed the trany, and still have the same problem. if anyone has any suggestions please let me know
i had a friend that had the same problem with a 93 f-150 with a 302 in it after 6 months of changing every thing out an still having the problem i took the mass air out to look at taking the screen out an what i seen was the wire in the mass air broken . changed it out with a junk yard 1 an the truck never had the problem again .
hope this helps you
mark
