Sponsored by: Real Truck
What's the best bug shield?
Old Feb 20, 2002 | 01:37 PM
muligan's Avatar
muligan
I want to put a bug shield on my SD but I want a good one that doesn't wear the paint off and also screws on and off.
Any recommendations?
Old Feb 20, 2002 | 03:15 PM
NoMo's Avatar
NoMo
Someone mentioned that the Weathertec(sp?) version uses fasteners instead of tape. I also think that the Bugflector series from Ventshade can use tape or screws.
Also, you can usually manipulate the installation position of the shields so that there is no contact with the hood.
Old Feb 20, 2002 | 08:05 PM
95rcobra's Avatar
95rcobra
Check out the website of www.lundinternational.com
they own a few different companies that make the hood sheilds with some different styles to choose from. most of these shields are No drill installations. good luck 95rcobra.
________________________
2002 F250 SD SC SB Lariat V10.
1995 Cobra R model #185.
Old Feb 20, 2002 | 11:05 PM
Outpost22's Avatar
Outpost22
I highly recommend the Bugdeflector2. Easy fit and removal AND you can buy it to color match your truck. (Check the white one in my gallery)
Old Feb 21, 2002 | 10:02 AM
muligan's Avatar
muligan
Hey outpost22, not to change subjects but what kind of tie down system are you using for your lance. Have seen bad photos of damage done by using happijac system like I had on my previous truck. I was recommended to use a frame tie down system.
Old Feb 21, 2002 | 03:43 PM
RockyMountain250's Avatar
RockyMountain250
The one I have is made by I think magnum or at least that is in the title. It screws into 3 holes under the hood and fits great. I would recommend this one to any one looking for a bug deflector....If you are interested I could look tonight and post the manuf. in the a.m.
Old Feb 21, 2002 | 07:38 PM
NoMo's Avatar
NoMo
Old Feb 21, 2002 | 10:00 PM
muligan's Avatar
muligan
Thanks for the advice, I settled on the Lund Interceptor. This one stays away from the hood but still looks aerodynamic. It also mounts using 4 existing holes in the hood with self tapping screws. Much better than the MPC setup I had on my last truck. Much appreciate your comments.
Thanks,
Muligan
Old Feb 22, 2002 | 09:21 AM
Outpost22's Avatar
Outpost22
>system.
To reply to the off-topic question with an off-topic answer:P
I too prefer a frame mount system. However, with a brand new truck and a Ford dealer telling me "Ford doesn't like frame mounted camper systems because they put side-loads on your frame. It could cause warranty issues if your frame cracks". I went Happijack. When the warranty is over, I'm going frame mount Besides, if I'm ever in a situation (God forbid) that the camper decides to unintentionally leave the truck, I'd rather have it do it without me attached ... just kidding
Old Feb 23, 2002 | 10:24 AM
PeteC's Avatar
PeteC
Bugflector is the way to go. I have a gold deflector to match the truck. I bought it from Walmart. They had to special-order it; it took about 5 days to get in.
Old Feb 23, 2002 | 08:06 PM
aqhacool's Avatar
aqhacool
[updated:LAST EDITED ON 23-Feb-02 AT 09:07 PM (EST)] Lund is the best. Get a clear one and have the inside painted to match your truck.
Todd
Old Feb 24, 2002 | 03:04 PM
Thaid
Guest
Posts: n/a
I've been eyeballing the Lund Interceptor Stainless Steel deflector. Thought it would look good with the chrome grill against the woodland green body color.
Anybody run one of these?
Quadsport
1997 - 2003 F150
Oct 7, 2012 08:49 PM
riley ruffen
2004 - 2008 F150
20
May 27, 2005 08:58 AM
BongoCongo
May 18, 2004 04:48 AM
FordCrusier
Apr 7, 2004 02:50 PM
BroncoScott
Appearance & Dress-Up
Oct 31, 2003 05:19 PM
