Ford In Trouble
Old Feb 22, 2004 | 08:02 AM
  #106
twoballsleft's Avatar
twoballsleft
tn mac- kinda on the 8 leaf...new pack is 6 plus org 2. http://www.suspensionconnection.com/...&mv_arg=229593
Haven't had a chance to measure anything yet, pick it up mon, but it looks like 3" might be needed...super lift hac a 10 leaf pack...$632 Heres what I was looking at.
http://www.rockymountainsusp.com/fd4_99f2_350.htm
Old Feb 22, 2004 | 08:10 AM
  #107
Choctaw Bob's Avatar
Choctaw Bob
I'm think about slamm'in mine. I'm afraid mine is too unstable at 140 MPH
Old Feb 22, 2004 | 09:10 AM
  #108
twoballsleft
Choctaw, u funny guy..
Old Feb 22, 2004 | 09:28 AM
  #109
"Luke" SdeS's Avatar
"Luke" SdeS
Fm Blackhat
Either the flash didn't take correctly or you have a bad sensor in the system
Or, most likely, the very precise procedure for installing the new calibrations was not followed. I.E., as has been emphasized elsewhere on this forum, the tech did not use a battery charger while affecting the installation.
Old Feb 22, 2004 | 09:56 AM
  #110
Choctaw Bob
We probably need to memorize the proceedure so we can personally supervise the techs.
Old Feb 22, 2004 | 08:34 PM
  #111
tn mac's Avatar
tn mac
Its bad when the owners know more then the tech.
Old Feb 22, 2004 | 08:39 PM
  #112
Choctaw Bob
Good for us.
Old Feb 23, 2004 | 08:13 AM
  #113
"Luke" SdeS
Fm Choctaw Bob
Good for us.
Ditto......
Old Feb 24, 2004 | 04:58 PM
  #114
twoballsleft
He guys....they took my truck....check out my post....
You won't believe this!...They just took my truck! - in the Super Duty Forum
Old Feb 24, 2004 | 05:15 PM
  #115
RJB1's Avatar
RJB1
4 & 5th gear tranny brake
Originally posted by blackhat620
tn mac,
Choctaw is correct. Either the flash didn't take correctly or you have a bad sensor in the system. In either case i would take it in to the service department and have them fix it. The tow haul should work in 4th & 5th with a touch of the brakes, there is definitely a problem with yours.
Good luck
Are you saying that with the 3U7A Flash the tranny brake should still work in 4th and 5th??? I had mine flashed 4 Jan and It does not work until I'm down to 45 MPH!! That is with or without a load.
Old Feb 24, 2004 | 07:52 PM
  #116
tn mac's Avatar
tn mac
RJB1
thats exactly what mine does only 40 mph. that is not a good trans brake you have to brake to get it to that point, it is only using trans for a very short period.
Old Feb 24, 2004 | 11:25 PM
  #117
blackhat620's Avatar
blackhat620
Thats exactly what i am saying. If you touch the brakes in tow haul 4th & 5th will work as previous before flash.
Hope this helps
Old Feb 25, 2004 | 01:25 PM
  #118
tn mac's Avatar
tn mac
blackhat620
you can touch the brakes on my truck but it will not slow you down in 4th or5th gear, it kicks in at 40mph and down shifts twice. tryed it with trl. and without no diff. tryed it touching twice , tryed touching once, tryed touching 3 times doesnt work till 40mph.
Old Feb 25, 2004 | 02:15 PM
  #119
blackhat620
tn mac,
Like I, Choctaw Bob and Luke SdeS, said in previous posts, there is definitely something wrong with your truck/transmission if the Tow/Haul mode is not engaging until you slow down to 40mph. IMO i would take your truck to a knowledgeble Ford 6.0 diesel tech and have them find out what is wrong with your truck/transmission.
Hope this helps
Old Feb 25, 2004 | 03:12 PM
  #120
RJB1's Avatar
RJB1
tn mac,
Hope this helps
Is there any documentation that states it should work in 4th and 5th??
I'm not questioning you guys, I just like to have proof before I challenge people. I specifically remember the dealer telling me it worked at 45 and 35 as examples.
