remove air pump from 90 5.0?
Hi y'all!
I just have a quick question... could I remove the air pump from a 90 5.0L and not replace it? Just get a shorter belt? At least, could I do this in a pinch, until I can find a used part? Want to get back to work fast as possible
Thanks,
walter
Thanks,
walter
I have noticed that some outfits offer an idler pulley and mounting bracket set to enable removal of the air pump and still use the stock serpentine belt. I assumed this mean't that a shorter serpentine belt was not available.
Anyone got a part number for such a shorter belt?
(for a 1990 302 with power steering but will not have the air pump installed).
Thanks,
Thanks,
I ended up just slapping another air pump in because I couldn't find a short enough belt. Cost of new short belt + cost of discarded newish belt = cost of air pump. So I figured, what's the difference (a few horses I guess).
Definitely runs better without the pulley siezed up
walter
walter
kyflaresideon20s
Oct 12, 2011 10:54 AM
jameslew07
Feb 25, 2010 05:35 AM
