Sponsored by: Real Truck
Do guages work?
Old Feb 28, 2002 | 09:57 PM
nothingbutford's Avatar
nothingbutford
Do guages work?
I want everyones opinion on wether you think the guages in the super-dutys work? oil level, oil pressure, and temperature. Also I wouldn't mind proof if you can give it. Thanks. Benjamin
Old Feb 28, 2002 | 09:59 PM
Monsta's Avatar
Monsta
Sit. Stay.
Do guages work?
AHHH you made it! What!?! You didn't like my answer up the General Forum?? What?!? You no trust da monsta aneemoor, huh???
They STILL don't work! Although my gas gauge seems to move quickly...
Old Feb 28, 2002 | 10:15 PM
FortyFords's Avatar
FortyFords
Do guages work?
No don't start that gas mileage thing again!
Monsta you know better!
No they stink ,like monsta said ! but I only have 1600 miles on the truck
so what do I know
Well I'll be installing some real gauges soon , problably a-pillar
or something else if i put the the a-pillar handle like "Abendx "
either Stewart Warner or Sentry
Any other suggestions welcome!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
Old Feb 28, 2002 | 11:08 PM
Monsta's Avatar
Monsta
Sit. Stay.
Do guages work?
I hear Autometer makes some good ones!
Old Mar 1, 2002 | 06:35 AM
nothingbutford
Do guages work?
Hey Man. Don't be so hard on me!!! I don't think that any of the guages work properly. But I have to prove it to my brother. If you know what I mean. He thinks they work, I think they don't. Benjamin.
Old Mar 1, 2002 | 07:43 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Do guages work?
The gauges work. They all move into the normal zone when the engine is running.
Did you mean do they give you real data, that you can use? The fuel gauge does, the voltmeter sorta does (it does move around, but it's very insensitive), the oil pressure gauge has two positions, normal and zero, the engine temperature does, kinda like the voltmeter, and if you have a factory transmission temp gauge, it works almost like the voltmeter, but it has three positions, very cold, overheated, and all other temperatures.
Mark
Old Mar 1, 2002 | 07:57 AM
J.C.'s Avatar
J.C.
Do guages work?
Nup, they don't work. You can tell just by watching them, they don't move. If you've ever seen a real oil presure gauge it is always moving. You don't have the same oil presure at idle as you do at 3000 rpms yet ours never move. The oil pressure sender is just a pressure switch. It's either on or off.
Somehow they've even screwed up the volt gauge. Turn the key to on, look at the gauge, start the truck and look at the gauge again. It's still in the same place! There is at least a 2 volt difference between a non running truck vs a running one yet the gauge doesn't move at all.
Engine temp gauge is also junk. Once the truck reaches operating temp the guage stays at the same spot until you reach 250 F and then the guage will peg. There is no in-between.
It's one of Fords better ideas.
Old Mar 1, 2002 | 06:40 PM
NoMo's Avatar
NoMo
Do guages work?
They "function" just like Mark K. said. I'd hate to use the word "work" though. ;-)
Old Mar 1, 2002 | 07:59 PM
stumpy2's Avatar
stumpy2
Do guages work?
