Hellwig Anti Sway Bar
I was having an aweful time getting my lift right and went through SEVERAL configurations before I ended up with the rise I like. One of them was OEM springs with ProComp add-a leaf and 2" blocks, assisted by the Hellwig. Decent ride, but seemed to push me through corners causing oversteer and it did tight bounces waaayy too much in corners and over small bumps.
the rise I now have is the Fabtech 5.5" springs with no blocks and no Hellwig. Now I actually accelerate through corners!
Don't blast me for this story:
Last fall a buddy in his Acura Integra and I were trying to make the Tuolumne Meadows Store in upper Yosemite via Hwy 120 to get some last minute things before a backpacking trip. Time was tighter than the corners on this twisting road. I was hitting 50-70 mph ripping through the trees and barely made it to the store. A FEW MINUTES LATER, my buddy arrived, short of breath asking, "I couldn't keep up with you! How does that monster corner like that?!!"
It rides a little rougher than before, but I'll get there first!
Why would they want to change until some competition comes along ?
they sell ALL they make and they figure we have REAL instructions all over the net... so....
we just have to live with the nice product...
!. Do them both at the same time. You have to take the lower shock mount off the axle to put on the new U bolt and add the hellwig plate. This is a lot more difficult with a new Bilstein shock pushing it down to the ground. Trust me.
2. Buy a few more 1/2" cut washer before you start.
3. The u-bolts need to be washered and you use the eight hex nuts that are not pinch nuts. Double nut the u-bolts.
4. The D-bracket that holds the sway bar to the plate that you put on the lower shock mount should be mounted on the top two holes, the lower of the top two holes is the top of the u-bolt. Use a washer and a 1/2" pinch nut for the top hole.
5. The u-bracket that is mounted on the end of the sway bar to hold the end-links is mounted with a washer and a 1/2" pinch nut.
6. put the rubber bushings into the end links first. Then take a file and file one end of the steel sleeves that go through the bushings. File the outside rim of the sleeve so that it will slide through the bushings more easily. You will have to use a hammer to get them through the bushings.
7. The bolts that hold the end links together (4) are the only nuts and bolts that you can figure out on your own where they go. They are the smaller bolts with a lock nut. No washer needed.
8. Adjust the end links so that the Hellwig is parallel to the ground. I cut one hole off of mine. I have a 4x4. I did it because everyone said too. I found it interesting though that the front swaybar installed by Ford is not even close to being level to anything. The sway bar looks like it is a 40 degree angle and the end links are the same.
9. You will have four bolts left to mount your end links to the frame and sway bar. The longer ones are used for the top frame mount, use three washers, two on the outside of the bushings and one on the other side of the frame. Pinch nuts are used here also. I didn't use any washers for the lower link connection to the U bracket on the end of the sway bar. Use a pinch nut there too.
10.Tourqe all bolts to the specs on the instructions. This is by far the most usable section of the instructions.
I put mine all together in an hour or so, was totally confused on what nuts went where, so I called tech support in the morning and talked to a nice man that straightened me out.
I hope this helps the next guy who puts his on. Oh, and by the way, grease the inside of the big D-bushing before putting it on.
Good luck.
I would, but I lost all my pictures of the install.
