Hellwig Anti Sway Bar
Old Feb 24, 2004 | 11:33 AM
jdadamsjr's Avatar
jdadamsjr
You're somewhat right... it's not deadly critical...
but it is important as stated to get the full benefit out of the bar...
if not mounted parallel, the bar is twisting in a different arc than the axle and you lose some of the effectiveness of the bar...
Granted, it will still function, but not as well as it could...
Old Feb 24, 2004 | 03:45 PM
spartan's Avatar
spartan
Mine are parallel to the ground as is appropriate with two inches of lift in the rear. One hole open top and bottom. I think Landyot's are covered four over four and his truck is not lifted.
Old Feb 24, 2004 | 08:29 PM
Rackpatrol's Avatar
Rackpatrol
I was wondering if the Hellwig Anti Sway Bar really works. I was thinking about putting a set on my 2000 Excursion. some one also sugested better shocks and air bags to take out the sway from wind and roads that pitch from side to side. MAN I LOVE THIS FORD TRUCK ENTHUSIASTS FORUM.
Old Feb 24, 2004 | 08:58 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
My experience with Hellwig, they will not sell it .......if it does not improve the vehicle.
I have one, not yet installed, but cannot wait.
Old Feb 25, 2004 | 12:07 AM
rodsterman's Avatar
rodsterman
Well get with it Tim, you wan't be dissapointed!!!!
Old Feb 25, 2004 | 05:27 AM
jdadamsjr's Avatar
jdadamsjr
Ditto Tim !
Not only will you not be disappointed, you'll be amazed at the difference in the X ! And wonder how you got around corners before it
Old Feb 25, 2004 | 06:45 AM
IB Tim's Avatar
IB Tim
Do you guys have front and rear?
Old Feb 25, 2004 | 08:10 AM
jdadamsjr's Avatar
jdadamsjr
on my 02 4x2 I just had front... then added rear Hellwig...
on current 03 4x4 I have stock front and rear...
Old Feb 25, 2004 | 10:27 AM
valenrandy's Avatar
valenrandy
i have a 01 psd 4x2, do i need to get both front and back? and how much are they? i dont know much about this, is it an easy install?
Old Feb 25, 2004 | 12:41 PM
IB Tim's Avatar
IB Tim
http://www.hellwigproducts.com/
Old Feb 25, 2004 | 12:58 PM
Cobra 427's Avatar
Cobra 427
My '00 4x2 came standard with a 36mm front anti-sway bar - I assume most, if not all, Ex's come standard with this same 36mm front anti-sway bar.
Conversely, my Ex didn't come with a rear anti-sway bar, and I assume that most Ex's don't have one either. I've heard that some '03 or '04 4x4 Ex's have come with rear anti-sway bars, HOWEVER, the issue at hand is whether your Ex has a rear anti-sway bar or not. If not, then it is highly recommended that you purchase/install the Hellwig Rear anti-sway bar. If Ex has a rear anti-sway bar already (either stock from Ford, or added previously), then this is not much of an issue.
Price is reasonable (like $100 or so).
Installation is easy - it's just a bolt on!
[going slightly off topic]
While you are at it, you should also look at upgrading your shocks and adding Landyot's Radius Bars
YMMV,
Randy R...
Old Feb 25, 2004 | 01:00 PM
valenrandy's Avatar
valenrandy
Thanks! i'll go to the 4-wheel shop and see....
Old Feb 25, 2004 | 04:24 PM
  #28
IB Tim's Avatar
IB Tim
My 03 came with two, however I am going with Hellwig on the rear, it is .250 larger. That is a consideraable amount.
Old Feb 25, 2004 | 04:44 PM
  #29
99 sd v10's Avatar
99 sd v10
I just went to install mine. The 3 hole plate has holes for 3/8 bolts. That would be fine if it came with 3/8 bolts. It came with 1/2 bolts. I had to call hellwig. Now it'll have to be next weeks project.
Old Feb 25, 2004 | 04:51 PM
  #30
IB Tim's Avatar
IB Tim
Home Depot has good grade bolts and so do automotive stores.......just check the top of the bolt.
