1978 - 1996 Big Bronco
Bouncing speedo needle on a 94
Old Feb 16, 2004 | 09:45 AM
irondragon79's Avatar
irondragon79
Ok, I've got my "new" 94 EB Bronco, I already love it, but I do have a question about my speedo needle. It's ok for most of the speed range, but when I get on the expressway and get to over 65mph and try to hold a constant speed, the needle tends to jump a bit (+/- 1 or 2 mph). This normally wouldn't be a problem, execept when I try to use the cruise control, that jump in the needle is transfered to a jump in the actual speed, giving me a less than smooth ride.
You guys have any ideas on what I should check, or is this normal? I know with the amount of highway commuting I do, cruise is a real help with the gas milage, so any help would be appreciated.
Old Feb 16, 2004 | 12:11 PM
Corey872's Avatar
Corey872
We had a post on this a few months back. You may have to search for the other posts, but in summary:
Several people (myself included) have experienced similar problems. The quick-fix is to replace the rear-end speed sensor. This is where the tranny, speedo, cruise-control and ABS all get their speed info from. In some cases this may help, in some, it may not.
Someone also posted about a TSB which described how the rear-end bearings can wear and allow enough movement between the "tone ring" in the rear end and the sensor. This can make the pick-up of the signal unreliable and cause fluctuation.
Maybe some of the other people that were having trouble can chime in if they got it fixed, too.
Old Feb 17, 2004 | 08:57 AM
irondragon79
Is that rear end speed sensor a part you can get from a Napa type place, or is that a dealer part? I might as well give it a try, I don't think it would hurt anything to replace it and maybe that might help out the problem.
Old Feb 17, 2004 | 09:04 AM
Crazyromi's Avatar
Crazyromi
I had trouble finding that part at any of the local auto stores. I went to Strauss, Pep Boys, and AZ with no luck. I eventually ordered it off of fordpartsonline.com . Everything went smootly with them. I don't know if it would be easier/less expensive to go to your local dealer, but that was just my experience.
Old Feb 17, 2004 | 11:12 AM
bigric's Avatar
bigric
I got it at the dealer for $12; it's not expensive. Ask for the ABS sensor.
Old Feb 17, 2004 | 11:23 AM
Crazyromi's Avatar
Crazyromi
I think mine was about 15. Not very expensive and an easy item to replace.
Old Feb 17, 2004 | 12:36 PM
fordnut74's Avatar
fordnut74
Same here, one of the very few items that are actually cheaper from a dealer than a parts store
Old Feb 17, 2004 | 01:46 PM
irondragon79
Thanks for the help so far.
I checked with fordpartsonline and found these 2 sensors listed. So what is this other "vehicle speed sensor"? where is it located?
VEHICLE SPEED sensor, F150-350, Bronco 92-98 $42.47 $33.98
Electrical - Powertrain control - Vehicle speed sensor
or
REAR SPEED sensor, F150-350, Bronco 92-98 $18.33 $14.66
Brakes - Anti-lock brakes - Rear speed sensor
I'm going to check with my local dealer for the rear sensor and start with that. Its cheap enough and I figure after 134,000 miles, it wouldn't hurt to replace it anyways, and I'll see if it helps any.
kanuck15
13
Feb 1, 2014 06:30 AM
thomc
Jan 9, 2013 04:28 PM
ramrod7373
Dec 14, 2012 08:51 AM
stadium94
Apr 5, 2004 11:18 AM
karenj
Jan 10, 2004 10:02 AM
