Driver Door Rubbing/Noise
Old Mar 31, 2004 | 05:26 PM
  #31
general124's Avatar
general124
The di-electric tune up/connector grease finally arrived here in manila and the driver-side door rattle/noise is GONE. Also applied the grease to all the doors and rear opening and the interior now has never been that quiet.
Old Mar 31, 2004 | 05:30 PM
  #32
ExpyBob's Avatar
ExpyBob
Hey Guts
I'm glad it worked. I got 5 months of peace before the noise returned after 20-25 car washings. Our worst season.
I just re-applied on the drivers door, the rest is good.
Bob
Old May 4, 2004 | 10:38 PM
  #33
Mr. George's Avatar
Mr. George
Smile Gasket!!
What and where is a gasket?????
Top, bottom, side, where??
Thank you..
Chris
Old May 5, 2004 | 05:09 AM
  #34
ExpyBob's Avatar
ExpyBob
All the way around the front, top and rear of the door openinf. There is an inner large rubbery gasket and a smaller harde one on the outside of the first one.
Do both.
Old May 6, 2004 | 10:51 AM
  #35
Mr. George's Avatar
Mr. George
Lubricant
Thanks Bob.. I got the lubricant from Pep Boys today and put it on. I am driving to LA tommorow..I will test it then.(noise only happens at 60+mph)
I cannot believe I bought a 36,000 suv and I have to put a lubricant on the door.
Chris
Old May 6, 2004 | 10:54 AM
  #36
ExpyBob's Avatar
ExpyBob
Yea, I agree there. They should have used a different material.
The lube worked well with other folks, I hope it does for you.
It was very annoying, especially on lumpy PA roads where the frame flexes alot.
Good luck---Bob
Old May 16, 2004 | 10:25 PM
  #37
cobrah's Avatar
cobrah
Well.........
Originally Posted by alphascrew
Hey Everyone,
I have a 2003 Expedition I bought for my wife in 10/03.
It's going in tomorrow to get all 4 brakes redone with the new pads to fix the awful brake dust tomorrow morning.
It is also going back for an annoying rubbing noise/squeak on the driver door.
So far they have replaced the window run, body seal, latch, then finally I took them for a ride and showed them that when I apply pressure on the top of door while I'm driving the noise stops.
So with that they re aligned the door. He told me that they moved the door 1/16" of an inch. The noise went away for about 3 weeks and then it gradually came back.
Now, I will ask them to look a it again tomorrow, but I'm getting concerned that the door won't stay aligned.
Any thoughts or has anyone experienced this.
Thanks
I will relate to you a prob. I felt was comming from the door, it was a rub or rattle noise that sounded while I was in motion, from the pass. side door.
Sound can play tricks ... I attacted the door...I will not mention the cost of investigation.
I found the prob. myself " it was the top rack" above the sun roof. The bar that crosses over from driver to pass. side has some "play" only a few (.009 )clearance.
The wind turbulance when in motion would activate the bar to vibrate and the sound was projected to the door. (The headliner is aligned with materal that deflects outside sounds, thus accounts for the echo)
At any rate, after many hours of bucks and time I "cocked" one side of the roof rack adjustment and made certain the cross bar had no play at all.
Ask me if the sound is still present...
cobrah
At first I was not so concerned, but soon became
Old May 16, 2004 | 11:16 PM
  #38
Mr. George's Avatar
Mr. George
No noise at all!!!! (approx one week) The lubricant worked like a charm... Thanks Bob.
Old Jun 6, 2004 | 12:48 PM
  #39
ExpyBob's Avatar
ExpyBob
I put this ontop because this seems to keep coming up.
Old Sep 11, 2004 | 07:20 AM
  #40
Gearbanger's Avatar
Gearbanger
OK guys maybe I'm a dimbulb. I've had my '04 Expy into the dealer for a rattle coming from the driver's side window. Sounds like the window is loose or something. EXTREMELY IRRITATING!! I mean drive the truck into a telephone pole irritating.
SO, they put some white litium grease looking stuff in the tracks of the window itself. Did a terrible job too, and did nothing for the problem! Bob, are you talking about putting this silicone in the window track seals or on the seals between the door and the truck itself?
Old Sep 11, 2004 | 10:16 AM
  #41
ExpyBob's Avatar
ExpyBob
Gearbanger
It goes on the seal around the door opening of the frame. I also put avery small amount on the mating surface of the door.
Are you sure it's the window?
I first thought it was the window too but it still did it with the window open.
Bob
Bullitt390
2015 - 2020 F150
38
Aug 24, 2018 01:28 PM
r___r
General Automotive Discussion
Jul 3, 2016 03:51 PM
Junior Junior
Apr 25, 2014 10:58 PM
BAJI26
Dec 24, 2008 10:58 AM
88grandmarquis
Paint & Bodywork
Aug 28, 2005 10:01 PM
