If it will also start with a light touch on the throttle I'd guess a bad idle air control valve. See if Autozone will check for trouble codes. Have you checked for any vacuum leaks? If you hook up a vac guage you should get at least 18 inches.
does it smoke(black) when it finally fires? could have flooding problem when you floor it computer goes into flood mode & doens't pulse injectors. a bad tps will do the same thing but should turn on engine light. if it isn't flooding could be bad check valve in fuel pump do a fuel pressure leak down test to confirm this or try cycling key about 3 times to fully pressurize fuel system if it is bad valves in pump it probably won't set codes. good luck!!
Originally posted by 77redf250 does it smoke(black) when it finally fires? could have flooding problem when you floor it computer goes into flood mode & doens't pulse injectors. a bad tps will do the same thing but should turn on engine light. if it isn't flooding could be bad check valve in fuel pump do a fuel pressure leak down test to confirm this or try cycling key about 3 times to fully pressurize fuel system if it is bad valves in pump it probably won't set codes. good luck!!
