blend door adjustment
Old Feb 14, 2004 | 11:01 PM
gdays's Avatar
gdays
I just repalced the heater core case on a 97 Explorer, but when I reinstalled the blend door controller I noticed it was putting a lot of pressure on the door when you went to full high,The ford manual, nor alldata addresses this ,and I really dont want to brake this one.any sujjestions ,there were no codes on the self test, And I tried anouther controller with the same results?
Old Feb 16, 2004 | 08:05 AM
mjbach's Avatar
mjbach
There seems to be lots of breakage of the blend doors and I think it's due to overdrive of the actuator. If you look for the "free blend door fix" posts, you'll read about my speculation of exactly what you're seeing. After taking apart the actuator, we didn't spot an adjustment to the amt of drive either.
However, if yours ain't broke, don't fix it. Just read up on how to fix it in case it does break.
Brian Frank
May 24, 2016 06:41 PM
rexpedition99
Dec 2, 2015 01:14 PM
08superduty08
Jun 22, 2015 08:45 PM
F-WhiteThunder
Jul 12, 2014 04:47 PM
ppruitt
May 29, 2014 06:32 AM
