Interior Lights/Switch/Sensor????HELP
Old Feb 14, 2004 | 06:31 AM
RangerSue's Avatar
RangerSue
Angry Interior Lights/Switch/Sensor????HELP
Hi-
I have had trouble with this since the day I bought my Ranger. I have a 1999 XLT 4X4. The cab lights stay on for an extended period of time even when the doors are secure, also, my DOOR AJAR light has been staying on now TOO!
I have heard of several other Ford people having this problem too, so I was curious if there was any kind of recall on this or if anyone has an easy fix or an suggestions. Someone told me to get this fixed at the dealership is almost 100 bucks for each door! UGH.
Thanks for any help!
Sue
SueBeer@aol.com
Old Feb 14, 2004 | 07:05 AM
PSKSAM2's Avatar
PSKSAM2
Welcome to FTE!
It is a common problem, usually caused by the sensor switches in the door latches getting dirty. I had luck shooting some WD-40 into the door latch then opening and closing the door several times on both my '98's. This doesn't always work for everyone, so several people have replaced the door latches (probably your $100 solution) or more radically cut the wires to the switch and hard connected them so that the light is always off.
-Jim
Old Feb 14, 2004 | 06:35 PM
Dealford's Avatar
Dealford
Welcome to FTE RangerSue.
At the top of this board is a sticky called "Technical Information".
There is a post about the door ajar problem. Give that a read to see how much of it applies to your truck.
Old Feb 26, 2004 | 04:37 AM
RangerSue's Avatar
RangerSue
Talking
Thanks so much you guys! I figured out the technical forum after I posted, of course.
But, thanks so much for your help. I sprayed some teflon spray into the locks, latches, etc. and I haven't had a problem since. Thanks for saving me 200 bucks!
This forum rocks!
Sue
Stroker 6.0 fan
16
Jun 6, 2013 12:51 AM
CobraGT40
Jan 15, 2011 09:08 AM
TampaDave
May 5, 2010 05:04 AM
fobranch
Feb 6, 2008 06:15 AM
rosa70
Feb 19, 2005 11:04 PM
