Is synthetic really worth it?
Old Feb 13, 2004 | 02:30 PM
fordfan2018's Avatar
fordfan2018
Ive got a 66 f-100 with 352 V8 and 53,000 miles on it. its never been rebuilt. If i start using synthtic now will I get a lot more life out of the engine, or will it not make much of a diffrence?
Old Feb 13, 2004 | 02:37 PM
pipercub's Avatar
pipercub
A friend of a friend has a Dodge Caravan with 280,000 on it using synthetic oil. He started using the synthetic when it was pretty new though. I started using synthetic in my truck and I think it has a smoother running motor. I'd go for it, better late then never.
Old Feb 13, 2004 | 02:40 PM
pipercub's Avatar
pipercub
Forgot to mention that I know some people who use regular and synthetic mixed together. I've tried the sythetic mix before, but didn't notice anything different. I just spend a little more and go synthetic.
Old Feb 13, 2004 | 05:45 PM
pntrbl's Avatar
pntrbl
I went 403K in a little jap truck and never used synthetic. At 5K intervals I did change the oil 80 times! Started on Pennzoil and finished it off with Valvoline.
One of my painter's got it too hot one day and blew the head gasket and I never did fix it because the rest of the truck was pretty well shot by then. Poor thing.
Moral is: Doesn't matter what you use. Just keep it clean!
Old Feb 13, 2004 | 05:51 PM
BobbyFord's Avatar
BobbyFord
You don't want to break a new engine in on synthetic but I believe that after break in, there's no better oil to use than Mobil1. When I raced motorcycles professionally my mechanic used Mobil1. We never lost an engine because of an oiling problem.
I recently put a set of heads on a 390 of mine that had well over 100,000 miles on it. At the same time I replaced the rear main seal and oil pan gasket, that were leaking. When I removed the rear main bearing cap, there was virtually no wear on the main bearing. I pulled a couple of rod caps for inspection and found the same thing. Also, I believe that, when changed regularly, synthetic oil keeps the inside of the engine cleaner than conventional oils.
Old Feb 14, 2004 | 06:00 AM
ddavidv's Avatar
ddavidv
Synthetic can be a wonderful thing, however...
I would not use it in your truck. At that age, I doubt it will see any benefits from the increased cost. The biggest reason, though, is synth will leak out of any weak gasket or seal you have, while regular oil won't. No sense spending twice the $ on oil only to find half of it on your driveway. BTDT!
Old Feb 14, 2004 | 07:53 AM
Tedster9's Avatar
Tedster9
Synthetic is superior oil for both high and low temps, but it's not a permanent install, it still gets dirty and filters need to be changed out. Changing the oil itself is probably more important than whether it is synthetic or not. The filter is at least as important as the oil too. Several tests have been run with synthetic though, where the engine lasts years with only periodic filter changes and top off. (Fleet owners)
jeepnix
2010 - 2014 Ford SVT F150 Raptor
Oct 13, 2011 03:58 PM
Fomoko1
Oct 2, 2006 10:29 PM
rmalottwtes30
Dec 22, 2004 02:48 PM
bjoern
Dec 16, 2002 05:29 PM
Jimjdb1
Jan 12, 2001 03:30 PM
