302 0r 302 HO
Old Feb 13, 2004 | 11:41 AM
brix47's Avatar
brix47
Question 302 0r 302 HO
How can you tell if you have a 302 0r a 302 HO. The motor is in a 1988 Ford F-150.
Old Feb 13, 2004 | 12:00 PM
jwtaylor's Avatar
jwtaylor
Easiest way is the firing order.
HO is (starting from number 1--counter clockwise on the distributor)------- 1-3-7-2-6-5-4-8
Non HO (starting from number 1--counter clockwise on the distributor)-------- 1-5-4-2-6-3-7-8
Facing the front of the engine/truck
the cylinders are number starting from the left side front to back 1-2-3-4
right side front to back 5-6-7-8
later
Old Feb 13, 2004 | 02:06 PM
Bronco86's Avatar
Bronco86
is there another way? pulled wires off
Old Feb 13, 2004 | 03:49 PM
69Mustang428's Avatar
69Mustang428
the firing order should be cast on to your intake manifold
Old Feb 13, 2004 | 05:20 PM
EPNCSU2006's Avatar
EPNCSU2006
I don't think firing order is on EFI manifolds. If the 302 is in a truck, it is not HO, unless someone put it there. Ford never designated a 302 HO efi in the trucks.
Old Feb 13, 2004 | 06:00 PM
jwtaylor's Avatar
jwtaylor
As a thought, the haynes manual lists the H O firing order for 95 and later 5.0 motors installed in trucks. later
Old Feb 13, 2004 | 06:48 PM
EPNCSU2006's Avatar
EPNCSU2006
That's correct, but that doesn't necessarily make it a HO. I think the roller cam motors in trucks were 351 firing order - mass air 302's were definitely 351 order, but not labelled an HO.
Old Feb 13, 2004 | 09:05 PM
f100guy's Avatar
f100guy
i had a mass air engine in my 90 and it was definately the 351 order and it was a roller ready block, i just found that out. but it was not an HO. i don't even know if that motor in that truck was the one that came in it but i am positive about the MASS AIR and 351 firing order on it
Old Feb 13, 2004 | 10:22 PM
EPNCSU2006's Avatar
EPNCSU2006
^ It wasn't stock - Ford started putting mass air on very few '94's and a few more '95's and all '96's (referring to F150's with 302).
Old Feb 14, 2004 | 09:57 AM
jwtaylor's Avatar
jwtaylor
True. later
Greywolf
Mar 5, 2013 04:08 PM
badproduce
Engine Swaps
Apr 8, 2006 12:06 AM
gjordan456
Engine Swaps
Mar 3, 2005 02:46 PM
airharley
Dec 18, 2002 08:26 PM
SadButTrue
Oct 17, 2000 07:08 AM
