Front End Suspension 98 Expy
Old Feb 10, 2004 | 07:13 PM
great white's Avatar
great white
Just passed the 105K mark on my 98 Expy and was curious if I need to address any front suspension components (ie ball joints, wheel bearings etc). The vehilce drives fine other than a "clunk" on the front drivers side when I engage a bump, tire wear seems balanced. The only repair I have made to the suspension as a whole is a new set of shocks (at 80K) and sway bar links. Any advise .................................................. ..................................
What are the symptoms of a ball joint going bad?
Old Feb 10, 2004 | 10:41 PM
tsdrallyer's Avatar
tsdrallyer
Sloppy steering, increased uneven tire wear, vibfation, noise when turning whether still or moving, are all indications of suspension or stering related problems. If you have none of the above, don't worry about the ball joints until you do. Mine are oirginal at 123K miles and are doing just fine.
Old Feb 20, 2004 | 09:02 AM
kritter's Avatar
kritter
For what it is worth, I just rolled over 150K on a 97 Exp. and the right torsion bar snapped this morning. If your not familure with the suspension it doesn't have springs that support the front but long torsion bars that hook to the frame and lower A-Arm.
cdherman
Apr 5, 2011 11:47 AM
nmcqueen469
1983 - 2012 Ranger & B-Series
Jun 23, 2008 03:22 AM
berry1234
Jan 8, 2008 06:35 PM
uscav
Feb 6, 2007 03:30 PM
gcarmody
Sep 26, 2006 09:10 PM
